Time step too small?
Hi guys,
I'm running a transient simulation of a little truck model we have in the wind tunnel. Width Re is around 640,000 for this and I'm using DES. They have been getting a Cd value of around 0.29. I was always getting around 0.33 but ever since I reduced the size of the time steps I have gotten it to around 0.30, which is great. However, I noticed that when I reduce the size of the time step to around 0.002 s, the vortex shedding I had observed with time step 0.005 s disappears. So my drag coefficient has improved, but I feel there should be some shedding at the rear, as that's what is happening in the wind tunnel. Is my time step somehow too small to resolve the shedding somehow? I always thought going as small as possible was the goal. * It should be noted I made a small geometric change before lowering the time step...it is possible that small change has somehow eradicated the shedding, but I highly doubt it. |
The smaller timestep will usually mean increased temporal resolution and therefore more shedding, not less. If it results in less shedding then you may be approaching numerical round-off and that is limiting convergence. Have you tried running double precision?
Thanks, Glen. I'll see what happens when I run it in double precision mode...
