September 6, 2010, 02:28 |
Time step too small?
Derwin Parkin
Rep Power: 16 |
Hi guys,
I'm running a transient simulation of a little truck model we have in the wind tunnel. Width Re is around 640,000 for this and I'm using DES. They have been getting a Cd value of around 0.29. I was always getting around 0.33 but ever since I reduced the size of the time steps I have gotten it to around 0.30, which is great. However, I noticed that when I reduce the size of the time step to around 0.002 s, the vortex shedding I had observed with time step 0.005 s disappears. So my drag coefficient has improved, but I feel there should be some shedding at the rear, as that's what is happening in the wind tunnel. Is my time step somehow too small to resolve the shedding somehow? I always thought going as small as possible was the goal. * It should be noted I made a small geometric change before lowering the time step...it is possible that small change has somehow eradicated the shedding, but I highly doubt it. |
September 6, 2010, 07:39 |
Rep Power: 143 |
The smaller timestep will usually mean increased temporal resolution and therefore more shedding, not less. If it results in less shedding then you may be approaching numerical round-off and that is limiting convergence. Have you tried running double precision?
September 8, 2010, 00:03 |
Derwin Parkin
Rep Power: 16 |
Thanks, Glen. I'll see what happens when I run it in double precision mode...
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
AMG versus ICCG | msrinath80 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2006 15:15 |
VOF | özgür | FLUENT | 8 | January 6, 2004 08:23 |
