Home > Forums > CFX
Evolution of heat
Old   October 2, 2010, 07:49
Default Evolution of heat
Sas
Sas is on a distinguished road
Simulates the process of heating the material (limestone)
How to specify the properties to him that in the range 900-1000 degrees. is the absorption of heat in an amount of 1660 kJ / kg?
P.S. my interest and how to set the CFX heat from the passage of solid state reactions in the material.
Sas is offline   Reply With Quote
Old   October 4, 2010, 18:00
ghorrocks has a spectacular aura aboutghorrocks has a spectacular aura aboutghorrocks has a spectacular aura about
Cp is easy. Heat absorbed/given off due to chemical reactions is a bit trickier. Have a look in the tutorials for how to specify chemical reactions.
Old   October 5, 2010, 10:30
Sas
Cp is the specific heat as I understand?
It can be given to changing the length of the furnace.
And how to set that will be releasing heat to the material in the range of 1200-1250 degrees without using a chemical reaction.
Old   October 5, 2010, 20:17
I have no idea what you mean by this.
You cannot do it by adjusting Cp, unless the heat released/absorbed is small (which is usually not true). You may be able to do it with a source but probably the best way forwards is with a chemical reaction.
Thread Tools
Trackbacks are On
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
mass flow in is not equal to mass flow out saii CFX 2 September 18, 2009 08:07
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
