April 26, 2011, 03:29 |
Argon gas inside a steel tube?
Rep Power: 15 |
Hi everyone,
Welcome back after easter. I have a general doubt about whether it is possible to do the simulation in Ansys of compression of a gas inside surrounded by a steel tube and compressed by a metal which is 50% of the volume inside teh tube with only the pressure at the interface of the metal and argon given? If so what is the setup i have to use. should i use CFX? or static structural too? |
April 26, 2011, 22:14 |
Rep Power: 143 |
Sounds possible. Do you want to model the crushing process? What are you trying to achieve with the simulation?
April 27, 2011, 03:57 |
Rep Power: 15 |
I want to calculate the compression of the gas due to the metal. |
April 27, 2011, 19:26 |
Rep Power: 143 |
Why do this in CFD? Doesn't this follow a simple compressible gas law so can be calculated manually?
Tube inside a tube simulation | Rashmichem | Main CFD Forum | 0 | December 14, 2010 01:52 |
Calculation of burned gas inside tube | Algimantas | OpenFOAM | 1 | October 14, 2010 04:04 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
