Fluid-Structure Interaction
Old   November 10, 2010, 09:47
Default Fluid-Structure Interaction
David fernandes
Ervideiro is on a distinguished road
I am doing a study of a dissipation heat capacity of a material. I have drawn A box air and in its interior is the material. With the passage of air, the material will changed the heat to the air. In left box( fluid flow) we have only the part of the fluid and in the right only the solid. To make the mesh i had to make the supress of solid part, for example, in the fluid box( left box) . So you can shape only the part of the fluid and vice-versa.
I also know that just can obtain the results, if there is a interaction between the two boxes. I only can obtain the file.dat if the interaction plan between the fluid and solid exists. yes? But once I had make the suppress that interaction plan does not exist .
How I can create the file dat. to introduce in external solver coupling?
I must do so or another way of doing.
Note: I did not take in to a count the thermal expansion coefficient created in the left box since it is very small.
please help m
tanks
[IMG]file:///C:/Users/David/AppData/Local/Temp/moz-screenshot-2.png[/IMG][IMG]file:///C:/Users/David/AppData/Local/Temp/moz-screenshot-3.png[/IMG][IMG]file:///C:/Users/David/AppData/Local/Temp/moz-screenshot-4.png[/IMG]
Ervideiro is offline   Reply With Quote
Fluid Structure Interaction Apollo Main CFD Forum 5 July 4, 2011 16:15
Fluid Structure Interaction with FreeFem ++ Pierre Main CFD Forum 1 November 20, 2008 23:42
fluid structure interaction taru agrawal FLUENT 4 September 10, 2007 03:12
Fluid Structure Interaction Apollo FLUENT 8 July 7, 2004 17:54
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
