Home > Forums > CFX
Drag forces on a cylinder
Old   November 20, 2010, 02:27
Default Drag forces on a cylinder
saisanthoshm88 is on a distinguished road
I'm simulating in ANSYS CFX , the flow past a 2D planar cylinder ( of course it is a Dummy 3D problem in CFX.). I've used the following expressions to calculate the Total drag force on the cylinder:
Total drag force = force_x()@cylinder.
Another total drag force =
areaInt(Wall Shear X)@cylinder + areaInt_x(p)@cylinder.
While working with these expressions, which area does CFX consider , the projected area of the cylinder(= Diameter * length) (or) its total surface area ?
Best regards,
saisanthoshm88 is offline   Reply With Quote
Old   November 20, 2010, 07:09
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
It integrates over the surface, using the element faces as the things being summed up. So the areas being summed are the element face areas.
Thread Tools
Trackbacks are On
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Coefficient DRAG and LIFT - Cylinder 3D Jwolf CFX 11 February 4, 2010 06:08
Drag on non-infinite cylinder between parallel walls deltaquattro Main CFD Forum 0 September 10, 2009 13:01
Solver and geometry choose for drag coefficient calculation around circular cylinder at large Re lin OpenFOAM Running, Solving & CFD 3 April 16, 2009 10:50
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
