November 20, 2010, 01:27 |
Drag forces on a cylinder
I'm simulating in ANSYS CFX , the flow past a 2D planar cylinder ( of course it is a Dummy 3D problem in CFX.). I've used the following expressions to calculate the Total drag force on the cylinder:
Total drag force = force_x()@cylinder. Another total drag force = areaInt(Wall Shear X)@cylinder + areaInt_x(p)@cylinder. While working with these expressions, which area does CFX consider , the projected area of the cylinder(= Diameter * length) (or) its total surface area ?
Best regards, Santhosh. |
November 20, 2010, 06:09 |
Rep Power: 143 |
It integrates over the surface, using the element faces as the things being summed up. So the areas being summed are the element face areas.
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 06:24 |
Coefficient DRAG and LIFT - Cylinder 3D | Jwolf | CFX | 11 | February 4, 2010 05:08 |
Drag on non-infinite cylinder between parallel walls | deltaquattro | Main CFD Forum | 0 | September 10, 2009 13:01 |
Solver and geometry choose for drag coefficient calculation around circular cylinder at large Re | lin | OpenFOAM Running, Solving & CFD | 3 | April 16, 2009 10:50 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
