parallel solving
Old   December 5, 2010, 14:02
Default parallel solving
kate
katiyon is on a distinguished road
Send a message via Yahoo to katiyon Send a message via Skype™ to katiyon
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver could not be started, or exited with return |
| code 255: . No results file has been created. |
End of solution stage.
This run of the ANSYS CFX Solver has finished.
I set up my CFX-pre file as a parallel run, but it send out this error. one time it didn't start to solve. it doesnt send out any error in serial run, what can i do? i want to use all my 24 processors...
katiyon is offline   Reply With Quote
Old   December 5, 2010, 17:15
Have you confirmed your multiprocessor setup works for simple simulations? Have you run a simple simulation like the Benchmark.def or a tutorial example on multiprocessor?
Old   December 6, 2010, 04:13
kate
Hi! what is the multiprocessor setup? what i have to do to confirm it? Ive simply choosed the first of parallel solving and then run it, sometimes it doesnt start to run and sometimes it encounters with above error...
Old   December 6, 2010, 06:38
Read the documentation section about setting up parallel simulations. It describes what you must do.
Old   December 6, 2010, 11:14
kate
Ive set everything according to the help ... It just starts to prepare but stays at solving section
Old   December 6, 2010, 17:02
Do the simple tutorial simulations run? <CFX_ROOT>/examples/Benchmark.def is a good one to try.
Old   December 7, 2010, 05:04
kate
it doesn't solve simple tutorials as well... what i have to do? isn't the software installed properly? Ive read in other post it may work with LAN connection, whats your idea?
Old   December 7, 2010, 12:55
Edmund Singer P.E.
singer1812 is on a distinguished road
Do you have 24 hpc licenses or 2 hpc pack licenses? You can't just solve on 24 processors without the parallel licenses.
singer1812 is offline   Reply With Quote
Old   December 7, 2010, 13:09
kate
Hi friends,
Thanks for your supportive responses... I finally find out why the software doesn't solve in parallel mode, It was because out network adapter didn't work (disables). I just connected the PC to others in Lab and then It ran...
Many many thanks....
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
