two separation bubbles
Old   December 13, 2010, 12:54
Joshua Counsil
Josh is on a distinguished road
It looks like you posted an instantaneous Cp distribution. Those "multiple laminar separation bubbles" could be start-up/shedding vortices. If you average the Cp graph over time, you should obtain a better Cp distribution (the sharp spikes in the Cp graph should average to a plateau).
Josh is offline   Reply With Quote
Old   December 13, 2010, 16:24
And a point from my previous post - what do you mean by PISO? This is not an option available in CFX.
Old   December 14, 2010, 01:53
Muhammad Aqib Chishty
aqib is on a distinguished road
PISO is actually present in Fluent 12.0.16 CFX.
The Pressure-Implicit with Splitting of Operators (PISO) pressure-velocity coupling
scheme, part of the SIMPLE family of algorithms, is based on the higher degree of the
approximate relation between the corrections for pressure and velocity. One of the limitations of the SIMPLE and SIMPLEC algorithms is that new velocities and corresponding fluxes do not satisfy the momentum balance after the pressure-correction equation is solved.
aqib is offline   Reply With Quote
Old   December 14, 2010, 02:28
Joshua Counsil
This is the CFX forum. Your question should be posted on the Fluent forum.
Any luck with the averaging?
Old   December 14, 2010, 03:48
How the averaging is being taken? I don't know about that!
Old   December 14, 2010, 03:49
Post
  #26
now my graph of Cp is like that after taking the time step size of 0.001.
Old   December 14, 2010, 04:47
Yes, Aqib, I am well aware of what PISO and SIMPLE is. CFX only uses a coupled solver, very similar to the coupled solver in Fluent (the coupled solver in Fluent is from CFX technology, and for ancient history buffs the coupled solver in CFX came from Tascflow which was purchased by CFX years ago.)
Old   December 14, 2010, 05:11
i think you can't understand....
Old   December 14, 2010, 05:27
Can't understand what?
Old   December 14, 2010, 05:37
About PISO scheme
Old   December 14, 2010, 05:43
I am well aware of what the PISO scheme is. PISO is an option in Fluent, and is not available in CFX - and this is a CFX forum. So what don't I understand?
Old   December 14, 2010, 05:59
mine mistake :-)
Old   December 14, 2010, 13:38
Joshua Counsil
That Cp graph looks much better. Did you average the Cp values over time?
Old   December 22, 2010, 02:11
are you talking about the single value averaged on the whole blade? Are you asking about the mean value of Cp plot over the complete flow time?
If you are talking about the first case then should i average the value on the vertex or facet?
Old   December 22, 2010, 11:02
Joshua Counsil
I'm talking about Cp averaged over time.
Old   December 22, 2010, 13:53
i can't understand how to get that?
Did i take Facet Average over Blade?
How to take the Average Cp over time?
Old   December 22, 2010, 16:30
Joshua Counsil
You'll have to export the Cp data at each timestep, which can be done with a batch file, then write a macro that averages all the Cp files.
Old   December 24, 2010, 01:20
I calculate the Pressure co-efficient value by two methods tell me which is right....
1. I record the Pressure co-efficient value and select the "Integral" in Report type option(In surface Monitor) and after 4.4239 sec my average value is: 0.467477514
2. I record the Pressure co-efficient value and select the "Facet Average" in Report type option(In surface Monitor) and after 4.4239 sec my average value is: 1.063549129
Tell me which method is right and which value is more accurate?
Old   December 24, 2010, 01:21
My Velocity Ratio is:
Vout/Vin = 1.779
is it ok?
wall function and flow separation O.D.Y. FLUENT 1 October 3, 2011 16:27
Viscous model problem with bubbles in multiphase Shin FLUENT 0 March 10, 2008 17:31
Bubbles in vertical pipeline JM Main CFD Forum 1 March 9, 2007 13:11
Bubbles Søren CFX 0 April 12, 2002 04:01
Euler + separation again Oliver Main CFD Forum 23 June 19, 2001 12:47
