Home > Forums > CFX
Need Help, rotating Impeller
Old   December 8, 2010, 13:59
Smile Need Help, rotating Impeller
ajinsan is on a distinguished road
i'm studying mechanical & process engineering in germany.
I am working on my bachelor thesis for about 6 weeks now. In my university there was no stuff like simulation softwares , so everything about cfx was absolutely new to me.
In these past 6 weeks i learned a lot about cfx and its theoretical backgrounds. This forum was a great help, and i’m very grateful for this community.
Now i am reaching a point, where i cant finish my works without somebodys helps. So I try this way, maybe someone here could support me.
First I need a confirmation for my works, wheter it is right or wrong. Secondly i would like to provide some questions about things which arent comprehensible for me.
1.)
The attached picture shows the fluid model i have designed in design modeler using the enclosure function. I have seprated the model into two stationary and one rotating domain.
The impeller doesnt exist as solid. While the rotating domain is set up with a angular velocity, the „Wall_rotating_frame“ is setting to „Counter Wall“.
Following BCs are adjust in this simulation:
Inlet :
massflow; turbulence option zero gradient
Outlet:
Opening ; opening pressure and dirn 0 Pa; turbulence option zero gradient
GGI Interfaces @ contact areas:
general connection; frozen rotor; pitch change automatic
It is a single phase, steady state simulation with a reference pressure of 0 atm using shear stress transport (as i read its the best option).
The massflow and the angular velocity oft the impeller are known values, which i gather from a experimental test. Also the pressure drop is known.
I want to know the following results:
- The force in fluid direction which affects the impeller
- The torque at the impeller
Does this work?????
2.) In post processor the streamline rotates in the wrong direction althoug i define a positive angular velocity, so i must set up a negative value.
Thereafter everythings working fine and the streamline goes into the right direction with an apparently realistic course.
Just dont get it, doesnt the rotation be subject to the right hand rule???
Im sorry for grammatical and spelling mistakes.
Hope sbdy can help me. I still have two months to finish my thesis.
http://img811.imageshack.us/img811/8636/fluidmodel.jpg
ajinsan
ajinsan is offline   Reply With Quote
Old   December 8, 2010, 14:50
joey2007 is on a distinguished road
I am not really an expert on turbo machinery simulation. However I will comment a bit on your setup.
  • The combination of massflow boundary with pressure boundary should be good solution.
  • Frozen rotor means that you model the geometry stationary and the influence of the rotation by rotational forces. It depends on the physics if these assumptions give reasonable results. Subsequently it is not resonable to just describbe the setup and then ask if it is right. The answer depends on the setup and the "real" physics of your application. So description of the latter is also required.
May be the others can comment a bit more.
Allow me some additional remarks: IMHO Neither it can be expected from a bachelor student to know this stuff nor it is healthy to work in while the short time of a bachelor thesis without any support by a experienced advisor. So my recommendation for your future master thesis seek better advisors who can explain you the stuff you can not know from your lectures.
joey2007 is offline   Reply With Quote
Old   December 9, 2010, 04:11
Default Rotating Impeller
Saravanakumar
saravana is on a distinguished road
Hi Ajinsan,
Welcome you to the field of simulation.
As, I have been working with similar Impeller simulation for some time, I think i can help you to some extent.
1. If you apply "Counter rotating wall" condition to a rotating domain wall, then those walls will be considered as stationary one. So just have a cross check over there.
2. opening pressure and dirn 0 Pa: This boundary condition need to be checked again. Because in general Impeller pump produces some considerable perssure depend upon the application. So 0 Pa seems to be bit unrealistic. The problem of rotation in the opposite direction may also be because of this!.
3. If you have considered the complete Impeller model in CFX you can give pitch change option as None.
4. Force and Torque can be calculated very easily using CEL commands with proper surface selection.
Best wishes.
Saravana
saravana is offline   Reply With Quote
Old   December 9, 2010, 04:48
Default Need information
Ronald Hutauruk
Hutaru is on a distinguished road
where the right place and the right site to get any tutorials of ANSYS CFD, particularly in Ship RESISTANCE???
Hutaru is offline   Reply With Quote
Old   December 9, 2010, 05:55
Max Efficiency is on a distinguished road
You are right with the direction of rotation: Your thumb of your right hand is showing in the positive direction of z-axis (rotation axis). Your curved fingers then shows the positive direction of rotation. Don't forget: the impellers of blades in pumps etc. are often backwards curved. Keep that in mind when using right hand rule.
And don't forget: in Post you normally analyse the relative velocity components. They are showing in the other direction (compared to absolute velocity components).
And please be careful: Within a rotating domain the velocity-setting "counter-rotating" for wall-boundary means, that this wall is a stationary wall without any rotation. You need this options for walls in a rotating domain, that are still standing in reality (for example walls that belong to the casing).
Max Efficiency is offline   Reply With Quote
Old   December 9, 2010, 18:15
Thanks everybody for replying.
As the Inlet-Domain and Outlet-Domain are stationary domains, i thought i always would have to apply the "counter rotating wall" condition for those walls?!?!
I already changed the outlet boundary condition. now it is 2 bar.
In my simulation I defined some input parameters for inlet and angulary velocity.
Inlet: 50 l/min , 40 l/min , 30 l/min, 20 l/min
Outlet: 2 bar @ every design point
Angular Velocity: real values which depend on volume flow (Expression:massFlow/997[kg*m^-3]*60[s*min^-1]*1000[l*m^-3]*number of revolutions[rev*l^-1])
The mesh consists of 400 000 elements. The contact areas (ggi interfaces) are adjust at 100 relevance.
The solver runs 300 iterations per design point.
The results seems correct to me. The streamlines rotates in the right direction and in a realistic whirl. Showing vectors on the impeller provides arrows in the rotation direction.
Though I am thinking I am on the right way, I am insecure because of the display of the streamlines. I dont know which display options are right.
I took the velocity streamlines on stn frame (hybrid) as i think it is posting the right running of the streamlines.
Now I believe it is not right because conservative results shows more realistiv flow. Is it because hybrid let them streamlines interrupt at walls because of the wall boundarie conditions (velocity= 0)? I have read the definition of hybrid and conservative in the help before, but it would be great if somebody could confirm my thoughts.
For my goal it is not important wheter the results on the impeller (force, torque) are highly accurate or not , because I just need trends for comparing two models.
Thank you all for your help.
I caught a cold yesterday and I am feeling very sick, so I am really sorry for spelling and grammatical mistakes or when something is incromprehensible.
ajinsan
Old   December 15, 2010, 05:30
Turbomachine is on a distinguished road
firstly, as for the boundary conditions, you have to set the inlet and outlet as stationary. However as soon as we are talking about he rotor it is defined in a rotating reference frame, hence the counterrotating adjustment for the shroud it appropriate.
secondly, im am not sure why you are working with an opening type outlet. This is not a proper boundary condition for an impeller, because it allows reverse flow to occur. I would recommend setting an outlet type condition intead. If the flow solver crashes because of reversed flow at the outlet, try moving the boundaries further away instead.
thirdly, i think you should reconsider the boundary conditions you are using. Recently, you have changed the outlet pressure from 0 to 2 bars which is a huge change. It the impeller is runnign at low speeds you can still get surprisingly good convergence, but the results will be far away from the reality. To put it in another way, you can get nice colourful plot, steamlines etc., but the significant data i.e pressure ratio, efficiency will be completely false. You must also get an accurate work input value to get correct results.
suggestions: try to determine the outlet pressure of the inlet first at design point with 1D calculations. Hint: use the TE and LE angles and the mass flow rate. Check the velocity triangles and Euler's pump equation. Your may also have to write a few program lines to iterate. Only then go about doing the simulation.
Turbomachine is offline   Reply With Quote
Thread Tools
Trackbacks are On
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 09:53
Rotating impeller Pedro Lima CFX 15 January 27, 2012 06:33
Mixing model with rotating impeller problem 201 CFX 10 May 14, 2010 11:59
Problem with rotating impeller brahim OpenFOAM Running, Solving & CFD 5 October 26, 2005 13:49
Boundries of rotating impeller created in Gambit ? Mounir FLUENT 2 October 23, 2000 06:56
