Home > Forums > CFX
open channel flow-sst model
Old   December 14, 2010, 05:55
Default open channel flow-sst model
antonio is on a distinguished road
Hi all. I am trying to simulate a free surface flow over a hydraulically rough bed using the sst model. In order to have a decent behavior of this turbulence model I would like to ask how can I assure, in a practical point of view, that I have at least 15 nodes in the boundary layer (value presented in the documentation)?
Apart from the fact that y+ should be more or less equal to 1 is there any other recommendation when creating the mesh?
It would be very helpful to hear the feedback of all.Regards
antonio is offline   Reply With Quote
Old   December 14, 2010, 06:46
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
I don't think you can do hydraulically rough flow without wall functions (ie y+>11). You should not integrate to the wall for this type of flow.
So put the first node at about y+=15, and grade out from there with a ratio of between 1.01 and 1.05. Hopefully that will have about the right BL resolution for you.
Old   December 14, 2010, 08:50
Sorry Sir, but i did not fully understand your explanation.
According to the documentation it says that sst model is based on the k- w model and has the same automatic wall treatment, which consists in switching between a low-Reynolds number formulation at low y+values and a wall function approach at higher y+values. Moreover it says that one can account for the roughness effects by considering a hs+ parameter.
Old   December 14, 2010, 17:31
You are right, you can model rough walls while integrating to the wall. But it does not sound like a good idea, unless you need detailed information about the boundary layer then it would be best to use wall functions. This means start with a mesh which has the first node at y+=15 to 20 or so.
Old   December 15, 2010, 05:17
Hi.
That`s precisely my case. Basically I am computing some quantities near the wall whose value at moment is very low. I think that can be caused by a bad separation prediction. Thatīs the reason why I have changed for sst model.
Old   December 15, 2010, 05:55
SST can handle the first node at y+>11 just fine. You don't need to integrate to the wall.
Old   December 15, 2010, 06:27
Hi,more two questions please:
Can you tell me why do you consider that`s not a good idea to integrate to the wall and why should I use the first node at y+=15 (or something like this)?
Do you think that even if i put the first node at y+=15, sst will "catch" the recirculation zones with more accuracy?
Best regards
Old   December 15, 2010, 18:44
Because a mesh using wall functions and a first node will have a smaller mesh by a factor of at least 15, and probably more like 100. That means 100 times less memory requirements and run time.
If wall functions work, then use them.
Thread Tools
Trackbacks are On
[GAMBIT] Gambit & 3d open channel flow mesh problem esgee ANSYS Meshing & Geometry 7 April 10, 2012 00:51
fluent model open channel yani FLUENT 0 October 31, 2010 02:54
Yacht in Open Channel Flow andreimour FLUENT 1 October 14, 2010 23:54
Open channel flow Mehdi Moayeri FLUENT 0 August 26, 2008 10:55
Inclined Open Channel Flow Abe Gonzalez FLUENT 2 April 15, 2008 12:32
