[CFX] Set convergence level for additional variable |
December 14, 2010, 07:24 |
Lance
Rep Power: 22 |
Im running LES and have set my convergence level to 1e-6 which the solver reaches within a couple iterations. However, I have an additional variable and it takes about 10-15 iterations per time step for it to reach 1e-6. So, in order to speed up my simulation, I want to set a lower convergence level for the additional variable. Is that possible? I know that Fluent has the option to specify convergence level on each equation, it would be great if CFX also had that option. |
December 15, 2010, 07:22 |
Lance
Rep Power: 22 |
Update:
got some help from support, and yes, its possible to have different convergence criteria for AVs. Just edit the CCL like: Code:
FLOW: Flow Analysis 1 SOLVER CONTROL: Turbulence Numerics = First Order ADVECTION SCHEME: Option = High Resolution END CONVERGENCE CONTROL: Maximum Number of Coefficient Loops = 10 Minimum Number of Coefficient Loops = 1 Timescale Control = Coefficient Loops END CONVERGENCE CRITERIA: Residual Target = 1.E-6 Residual Type = RMS END EQUATION CLASS: av ADVECTION SCHEME: Option = High Resolution END CONVERGENCE CRITERIA: Residual Target = 1.E-3 Residual Type = RMS END TRANSIENT SCHEME: Option = Second Order Backward Euler END END TRANSIENT SCHEME: Option = Second Order Backward Euler TIMESTEP INITIALISATION: Option = Automatic END END END END |
How to set convergence not using residuals | Stephen Gillen | FLUENT | 0 | November 28, 2008 07:03 |
Problem installing on 64bit with ver13 | jonititan | OpenFOAM Installation | 5 | May 12, 2006 18:42 |
How to set environment variables | kanishka | OpenFOAM Installation | 1 | September 4, 2005 10:15 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
level set for multi-fluids system? | Pei-Ying Hsieh | Main CFD Forum | 1 | July 19, 2000 16:42 |
