August 20, 2011, 20:29 |
@ Glenn
#21 |
Hareesh R Iyer
Rep Power: 15 |
Hi, pretty long time since I posted something here! Lateral sloshing can be simulated easily in CFX, but only managed to do so by lateral external excitation. How can the lateral slosh condition due to pitching be simulated?
August 22, 2011, 21:38 |
#22 |
Rep Power: 143 |
With a moving mesh approach you can move the tank in any direction you like.
August 22, 2011, 21:54 |
#23 |
Hareesh R Iyer
Rep Power: 15 |
@ Glenn..
Yes, am trying to crack it that way. If you find something sometime pls add it up here. |
December 20, 2012, 00:33 |
Help
#24 |
Rep Power: 13 |
Hi im new to CFD and i am trying to simulate tank sloshing for 10s but apparently my time does not run at all. It always get stuck at 0.0s even though the system is running. Can anyone help me with this? Help is greatly appreciated!
December 20, 2012, 00:34 |
#25 |
Rep Power: 143 |
Please post your output file.
December 20, 2012, 00:43 |
#26 |
Rep Power: 13 |
Hi as seen in the attached pictures, the water does not flow at all. The tank is moving at weird angles thou. Thanks for the help.
December 20, 2012, 00:52 |
#27 |
Rep Power: 143 |
Your simulation is in Fluent. Try the fluent forum.
But two general comments - have you set the gravity vector? And have you run the simulation long enough that the fluid would move? |
December 20, 2012, 11:56 |
#28 |
Hareesh R Iyer
Rep Power: 15 |
10s is fair enough for simulation
December 20, 2012, 16:44 |
#29 |
Rep Power: 143 |
Not necessarily, it depends on the length and viscosity scales (and a few other parameters, not sure what non-dimensional number that is). If the fluid is highly viscous it will take a while for the fluid to move enough that you will see it.
December 20, 2012, 21:00 |
#30 |
Hareesh R Iyer
Rep Power: 15 |
glenn is right..if viscosity, impulse time etc are high, 10s is insufficient
December 26, 2012, 03:58 |
How to input 'sin' eqn as part of the operating conditon
#31 |
Rep Power: 13 |
Happy boxing day everyone. With reference to the sloshing tutorial, instead of moving the tank in -9.81m/s in the x direction, may i know how do i input the speed if my speed is in the form Asinwt where 'A= ampitute', 't = seconds' and 'w = 2*pi*f'. For example, how to input 2.5sin(80*pi)t where the tank is undergoing a vibratory motion in the x direction. Thanks for the help!
December 26, 2012, 05:04 |
#32 |
Rep Power: 143 |
Replace the constant value with a CEL expression. Several CFX tutorials show how to use CEL expressions.
December 26, 2012, 09:52 |
#33 | |
Hareesh R Iyer
Rep Power: 15 |
Use CEL help to write functions.. 1st assign a func name say Gx.. and try as follows: Gx = 2.5 [mm] * sine((80 [rad/s] * pi()) * t [sec]) it depends on your omega, amp & timestep size. @ Glenn, Pl verify on the feasibility of this expression in CFX (actually I posted it without referring back)..so not sure if my memory is correct |
December 27, 2012, 05:51 |
#34 |
Rep Power: 143 |
There are a few minor problems with the CEL, but they would stop it from working and end the simulation with an error:
1) The sine function is "sin", not "sine". 2) The pi variable is pi, not pi(). 3) The variable t is already in units of time. There is no need to define units for t as they are already defined. Note I have not checked these through CFX either, but hopefully they are correct. |
December 27, 2012, 06:58 |
#35 |
Rep Power: 13 |
Thanks for the help, appreciate it! I will give it a try
December 27, 2012, 10:56 |
#36 |
Hareesh R Iyer
Rep Power: 15 |
Glenn, the CEL expressions have to be given such that each parameter is followed strictly by its unit in "[ ]"..otherwise you are correct.
Nathan, actually for acceleration as a variable expression, the 1st term in the sample excitation you asked would be steady state acceleration & not displacement. so the unit need to be "[mm/sec^2]" or so.. |
December 28, 2012, 04:28 |
#37 | |
Rep Power: 143 |
December 29, 2012, 20:41 |
#38 |
Hareesh R Iyer
Rep Power: 15 |
here is a sample working expression
Gx = 2.5*sin(20*t[s]/1[s]) if after a particular time, this excitation has to stop, use step function for the value of Gx by giving it as a new expression. Then call it into the acceleration definition of the problem. |
December 30, 2012, 06:25 |
#39 |
Rep Power: 143 |
I see, I was not aware an equation like that would even work.
Then I simply say it is bad practise. If the variable t is already a variable of time then the [s] is unnecessary, if the variable is of units other than time then I have no idea what it will do, but it sounds undefined. If you remove the [s] does it still return exactly the same result? |
December 30, 2012, 20:52 |
#40 |
Hareesh R Iyer
Rep Power: 15 |
if [s] is removed from t, then 1 [s] can also be removed, but there is inconsistency.
Tutorial to help tank sloshing modelling (CFX 12.1) | enghamed | CFX | 15 | August 27, 2019 17:45 |
Tank sloshing in fluent diverging...need help | lostin4ever | FLUENT | 4 | February 24, 2010 07:20 |
URANS in ANSYS CFX | brissyben | CFX | 3 | October 6, 2009 17:35 |
CFX transition to being part of Ansys | CFXQuestion | CFX | 12 | September 8, 2003 09:00 |
CFX 5.5.1 stirred tank and LES problem | Nishant | CFX | 2 | September 13, 2002 07:11 |
