Gidaspow model
hi
i am modeling a domain with 2 phases. one phase is water and other phase is dispersed solid. i selected Gidaspow for drag coefficient but it doesn't run and one error occur. when i select Schiller Naumann, program run but its results is incorrect. do you know that why this model don't run with Gidaspow model? |
Could you specify the more details of your problem,
What is the solid volume fraction and mean particle size in your case What was the error .. |
yes, of course. volume fraction of sand is 0.73 and mean particle size is 1.28 mm. i selected these options in domain:
maximum packing=0.62 restitution coeff= 0.8 fluid models= inhomogeneous for particles: kinetic theory is on. granular temperature model= algebraic radial distribution = Gidaspow turbulence= laminar solid bulk viscosity,shear viscosity and pressure model= kinetic theory drag coefficient= Gidaspow program don't run and no result file error is shown. do i define other option for remove this error and run it? do i define minimum volume fraction for it? |
Could you check whether your simulation run without an error when kinetic theory model is off and use simple model of gidaspow for solid pressure.
May be problem with the prediction of granular temperature value and check it Sometimes they may have unphysically large granular temperatures where the regions of low solid particle volume fraction. so in order prevent this, specify an upper bound for the granular temperature |
thank you very much for attention you. yes, i has run it without kinetic theory but results are incorrect.
how i can specify an upper bound for the granular temperature? |
There is option for specifying upper bound of granular temperature in Kinetic theory model ie., Maximum granular temperature option
what is the value of it? i don't find its value.
I dont know extactly the range of maximum granular temperature, May be you can look it in the literature
I prefered to give in the range of 0.01 m2/s2 Orlese you try different values to ensure the simulation results are independent of maximum granular temperature |
hi
In this model, i turned off kinetic theory, and used Gidaspow model with compact modulus = 100 for solid pressure. Is this model suitable for modeling Water and sediment? i modeled it inhomogeneous, is it correct or i should model it homogeneous? |
