Integration over portion of a surface
Old   July 15, 2010, 12:01
Default Integration over portion of a surface
Joseph Tipton
jtipton2 is on a distinguished road
I would like to know if there is an easy way to calculate a function on a portion of a surface in CFX Post. For example, what would be the easiest way to integrate the wall shear stress in the fully developed region of a duct flow? So far, the only work around I can see is to run the simulation, observe the flow development length, modify the geometry to split the duct into two regions, and then rerun the simulation.
jtipton2 is offline   Reply With Quote
Old   July 15, 2010, 19:05
Use a contour line to define your fully developed region on the surface, make a user surface defined by the contour, do the integration on the user surface.
Old   July 16, 2010, 09:08
Joseph Tipton
Thank you for the reply!
I let my axial dimension be the contour plot variable, made several user surfaces for each level of the contour in the fully developed region, and then combined them in a surface group. I'm assuming that's the easiest method.
Old   July 18, 2010, 06:18
If it works then it is all good.
Old   February 4, 2011, 17:43
mullenc525 is on a distinguished road
Is there way to apply this method to volumes?
mullenc525 is offline   Reply With Quote
Old   February 5, 2011, 04:53
Apply what method?
If you mean calculate functions on sub-volumes, then yes. Define a volume as a sub-region of the full domain and calculate the CEL expression on the defined volume.
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Numerical integration of 'T' across a 3D surface ACFD-student Main CFD Forum 5 March 23, 2006 15:51
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
