-   -   CFX solver error (http://www.cfd-online.com/Forums/cfx/83770-cfx-solver-error.html)
kh_thakor January 11, 2011 02:17
CFX solver error
| Job Information |
Run mode: serial run
Host computer: ENGG01
Job started: Tue Jan 11 11:43:37 2011
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Invalid diffusion coefficient VISCDYN_FL1 has been set for variab- |
| le TKE_FL1 in equation TKE_FL1 |
| Message: |
| Stopped in routine DEF_GAMEFF |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
This run of the ANSYS CFX Solver has finished.
CAN ANYONE PLEASE ASSIST ME IN SOLVING THIS ERROR???? :(
ghorrocks January 11, 2011 07:21
It is a little cryptic but pretty obvious - it has had an error calculating the diffusion coefficient in the k equation. Can you explain what you are doing and why this error may have come up?
kh_thakor January 11, 2011 08:11
I am conducting cfd for a control valve. I had meshed the flow portion in ICEM CFD with about 40lac elements. But later when I reduced the number of elements to 10 lacs...the problem vanished.
The problem is very simple. I just have to obtain the pressure distribution for various positions of valve opening(40%,25% and 15%)....
ghorrocks January 11, 2011 17:39
What is 40lac and 10 lac?
Sounds like a straight forward simulation. If you are getting errors like this then I would suspect your model is numerically unstable. Improve mesh quality, smaller timesteps and double precision numerics can help.
