How to run ".def" model with parallel CPUs
Old   January 4, 2011, 04:12
Smile How to run ".def" model with parallel CPUs
mohammad
mohammad is on a distinguished road
Hi every body.
I have created a model with CFX and want to run it with 4 processors.
when I try with "serial" option, it works but according to my model it takes a long time to be solved.
When I try using "MPICH2 local paralle" it fails always. The error is:
! Error #001100279 has occurred in subroutine ErrAction.
! Message:
! Incompatible sparsity patterns.
Does anybody know why? Is there any brave-heart to help me?
mohammad is offline   Reply With Quote
Old   January 5, 2011, 17:51
Ali Torbaty
AliTr is on a distinguished road
Are you able to run CFX examples in parallel?
If yes, do you receive this error during partitioning?
AliTr is offline   Reply With Quote
Old   January 6, 2011, 00:05
mohammad
Hi Ali,
I tried to solve some other CFD files in parallel and I was successful.
Plus,for your second question, when I run the file it works for some few iteration( usually less than 10 iterations) , and I don't have any problem during the partitioning stage.
So do you have any idea about that?
TNX
Old   January 6, 2011, 20:12
Ali Torbaty
Then "Incompatible sparsity patterns" makes me thinking somethig went wrong in solver side, did you try to alter the mesh either finer or courser which might change the sparsity patern?
Old   January 7, 2011, 04:05
mohammad
Hi dear Ali,
Actually, I changed my software again to Ansys 11 not 12. Now I'm trying to solve that problem...
You know,I'm trying to solve a wind tunnel and even for the same model, when i change wind velocity iwill have different errors..
I think that's normal because I must change my mesh arrangement, specially near the blade.
By the way! do you have any experience about wind turbine in CFD?
If yes, I want to talk with you about the proper turbulent model and mesh arrangement.
Regards,
Mohammad
Old   January 10, 2011, 18:00
Ali Torbaty
unfortunately wind turbines are not my field, I did model some wind farms but that didn't include the turbine's details. you might look around and find some close example helping you on that.
error #001100279, parallel computation
Parallel User Defined Real Gas Model aeroman FLUENT 4 July 1, 2015 06:09
Cant run in parallel on two nodes using OpenMPI CHristofer Main CFD Forum 0 October 26, 2007 09:54
Run in parallel a 2mesh case cosimobianchini OpenFOAM Running, Solving & CFD 2 January 11, 2007 06:33
How to run parallel in ICEM_CFD? Kiddo Main CFD Forum 2 January 24, 2005 08:53
stopping the model run co2 FLUENT 1 April 23, 2004 04:18
