Calculating the force exerted on an object from fluid pressure |
January 30, 2011, 14:54 |
Rep Power: 15 |
Hello all,
I'm using ANSYS 13 Workbench/CFX in order to determine the fluid pressure exerted on an obstacle inside an active pipe and from that, determine the forces exerted on the obstacle. I've managed to perform the simulation and produce a contour map of the pressures exerted on the obstacle (shown in the attached image). Now what I'm trying to do is use that information to determine the overall force exerted on the robot by dividing the pressure on each face by its area and then summing up the forces. However, short of simply doing this by eye and reading the pressure values from the diagram, I'm not sure how to use the actual data computed in CFX to determine the average pressure on each face. How would I go about doing that? Thanks --Amr |
January 30, 2011, 16:38 |
Rep Power: 143 |
Use the built in force functions. Much more accurate than calculating average pressures (and this approach does not include viscous forces anyway).
The CEL expressions like force, force_x, torque are what you are looking for. |
average, cfx, fsi, obstacle, pressure |
Display Modes | |
How to read pressure at discrete points | paka | OpenFOAM | 16 | April 28, 2020 07:26 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
DEFINE_CG_MOTION and pressure force | Teo Fumagalli | FLUENT | 0 | April 11, 2008 10:25 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
Too high pressure force ? | Tim Franke | Main CFD Forum | 1 | March 14, 2000 23:36 |
