January 21, 2011, 05:12 |
boundary condition at the wall
I would like to model mass transport using convection-diffusion equation. I want to apply a boundary condition of this type: − D ∇c n + u c n = Js, where c is the concentration, u the velocity vector and n the normal vector of the domain. Any help? Thanks in advance |
January 21, 2011, 06:35 |
Rep Power: 143 |
Are you proposing solving for c (or the flux of c) at the boundary (or something like that)? Sounds tricky. I think you will probably need to write a fortran subroutine for the boundary condition to do this.
January 21, 2011, 08:10 |
I want to solve for the concentration of a solute, but Js is a solute flux across the boundary (it is described by a simple CEL expression).
Can you give more details about what to program with fortran code, because i am not very familiar. Thanks anyway |
January 22, 2011, 05:02 |
Rep Power: 143 |
What is Js a function of?
What is D? What is known and what is not known in your equation? |
January 22, 2011, 05:14 |
thanks again for your answer
Js is a function of wall shear stress (known from solving Navier-Stokes) D is the diffusivity (known) u is the fluid velocity given by the Navier-Stokes (unknown but it is solved) c is the concentration (unknown and it is solved using the convection-diffusion equation) I want to calculate c at the wall which is described by the above equation. If you see − D ∇c n + u c n = Js is like convection-diffusion equation (transport equation in CFX: ∇(− D ∇c + u c) = 0) |
January 22, 2011, 05:29 |
Rep Power: 143 |
If you can recast it into a form like the transport equation then you can simply use an additional variable with a flux boundary = Js (or some function like it). But if that is not possible you have a much harder problem on your hand and you will need to write a solver in fortran to do it. I don't think example fortran comes with CFX any more, you would have to talk to the support people to get one I guess.
January 22, 2011, 06:17 |
Since Js describe the flux across the wall, could i use the flux in boundary condition?
But what is the mathematical formulation of this boundary condition? So that i could recast it in my form? P.S. the positive flux in describes direction into the domain. If i want it to move out of the domain, should i use -Js? |
January 23, 2011, 04:49 |
Rep Power: 143 |
For available boundary condition options see the documentation.
For what positive and negative does, give it a try and see what happens. |
isothermal wall boundary condition | Neil | Main CFD Forum | 3 | November 9, 2015 02:34 |
How to set rotating wall as boundary condition | babu | FLUENT | 7 | December 14, 2013 04:48 |
wall boundary condition in wall fired boiler | bharath | CFX | 0 | August 9, 2010 21:40 |
Change wall boundary condition in multiphase? | Jacques | FLUENT | 0 | November 27, 2008 06:26 |
Variable temperature wall boundary condition | Virginie | FLUENT | 2 | October 2, 2007 09:23 |
