-   -   local parallel overflow error (http://www.cfd-online.com/Forums/cfx/84263-local-parallel-overflow-error.html)
enghamed January 24, 2011 23:02
I am simulating a two-phase tank sloshing .
In the solver manager when I define the run if I run it as serial it is fine but if I do a local parallel and partition it, I get overflow error!
Why is this happening? what should I do?
Max Efficiency January 25, 2011 04:50
I have got the same problem with a single-phase-simulation including a stage-interface and one interface with rotational periodicty. I helped myself by starting the simulation as a serial simulation. After a few iteration I stopped the simulation and then started it again with the parallel option activated.
But of course, I am also very interested in the reason that is responsible for that error. If I remember correct, the error messages says, that there is not enough memory available. In my case memory allocated was about 500 megabyte and later on the solver asked for about 10 gigabyte...
enghamed January 25, 2011 06:08
I tried running first as serial and after stopping making it prallel but it didn't work for me.
I dont get memory error, i beleive I have enough memory, but I get overflow error when its parallel.
armlic July 12, 2014 06:45
Same problem
Hello enghamed,
Did you ended up figuring out your problem????
Which was the cause of your overflow? Im interested to know, I may have the same problem.
ghorrocks July 13, 2014 07:34
This happens a very small amount of the time. The usual cause is a free surface or some other high gradient thing (eg shock wave) aligned with a partition boundary. The usual fix is to use a different partitioning algorithm to move the boundaries to somewhere with more gentle gradients.
