Boundary Layer in Duct Flow
Old   January 26, 2011, 15:50
Default Boundary Layer in Duct Flow
Brady
recon9 is on a distinguished road
I am trying to verify the accuracy of CFX by modelling some simple flows. One such is flow through a square duct. I am noticing an odd velocity profile within the boundary layer. It starts at zero at the no-slip wall, climbs and peaks at a velocity greater than the free stream velocity, then lowers to a steady value approximately equal to the free stream velocity within the core of the duct.
As far as I understand flow theory, the velocity within the boundary layer should not exceed the inlet velocity. Does anyone know why this happens and if it can be fixed?
Thank you,
Brady
recon9 is offline   Reply With Quote
Old   January 26, 2011, 18:27
Yes, the result is correct.
If your inlet is a plug flow (ie constant velocity over the whole boundary), as the boundary layer grows it is a region of slower velocity. To maintain continuity then the flow in the middle must be faster than the inlet.
Old   January 26, 2011, 18:44
Brady
That makes sense, but should the boundary layer show a profile such as this? Sorry for the crude drawing, it should be symmetric.
Old   January 26, 2011, 18:47
Yes, that is normal. As the boundary layer develops the "bump" smooths itself out and ends up being a small increase in the duct centre velocity. But in the early stages of BL grow it starts as a bump in the velocity profile.
Don't take my word for it, do a literature search and find out for your self. Also, do a sensitivity study on your simulation (mesh, convergence, time step) and if it still gives the bump you can be confident it is real.
Turbulent Boundary Layer on a Flat Plate Hoshang Garda FLUENT 1 November 27, 2013 10:24
To thin boundary layer? Luk CFX 3 February 27, 2009 03:22
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Boundary Layer Meshing of a nosecone Chris FLUENT 1 March 15, 2005 12:42
Unsteady Boundary Layer Flow Wen Long Main CFD Forum 0 July 29, 2002 23:08
