[Sponsors] | |||||
Ugly Kid Joe
Rep Power: 3 ![]() |
I am simulating a (1-way FSI) flow over a cylinder case. My case is very similar to the one way FSI and mesh deformation Ch-22 tutorial. My question is that I need to validate my displacements but the disp observed is very low. What can be the reason ??? Is there a problem with the .CEL expression written???
The water flows in the positive x direction and displacement in the transverse (i.e y) direction is to be measured ????? I am attaching the .CCL file. Thank you. |
Ugly Kid Joe
In the ANSYS CFX reference guide Ch: 14 Functions in ANSYS CFX Pg. 150 says the following;
In all case if the wall shear data exist in the result file, the viscous force is added to the calculated force. How do I do this ????? Thank you very much. |
Rep Power: 42 ![]() ![]() |
First post - http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Second post - It is done by default, is it not? |
#4 | |
Rep Power: 2 ![]() |
Hi, Did you solve why the disp is very low? I have also exactly same problem. if you figure out what the problem is, please kindly let me know it. Best Regards |
#5 | |
Ugly Kid Joe
The first thing to do is use realistic values of spring stiffness (k) & damping values (c). I had actually assumed the values of k & C. The best paper to validate your simulations would be by Anagnostopoulos & bearman - "Response Characteristics of a vortex excited cylinder at low Re number". It is the only experimental paper I know that performed VIV at Re as low as 100. Also you might have low displacements because you vibrations must be in the lower or initial branch. Try to run simulations in the upper branch instead. Use the Strouhal relation given by Roshko (1988) to find the velocity at which your system vibrates in 2P mode of vortex shedding. If you need any papers related to VIV or any help with CFX just let me know, send me an email at vmlxb6@mail.mst.edu Hope that helped. |
#6 | |
then I turn on transient and put my ccl expression. the cylinder does not move ... do you have any idea about this situation? Best Regards, have you been experienced simulation at high re n |
Ugly Kid Joe
Am sorry but I have never encountered such a problem.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 9 | June 20, 2011 13:02 |
| Moving a Cylinder in cross flow after solving Dynamics equations of motion | maruthamuthu_venkatraman | OpenFOAM | 1 | November 19, 2009 13:55 |
| Flow over a flat plate & Flow over a cylinder | cfdxue | Main CFD Forum | 0 | November 26, 2007 23:26 |
| Anybody knows smth abt the flow around a cylinder? | Wenxuan | Main CFD Forum | 3 | March 20, 2007 17:19 |
| Flow over a cylinder | Anna | Main CFD Forum | 9 | March 24, 2006 14:32 |
