Home > Forums > CFX
Startup Additional Variables
Old   February 2, 2011, 20:39
Post Startup Additional Variables
FM
Felipe Matos is on a distinguished road
Hi
I'm trying to simulate a problem which requires an Additional Variable "av". The domain's DENSITY is a function of this av: DENSITY = f (av). This av is a function of TEMPERATURE: av = f (TEMPERATURE).
I give the initial temperature, but at the initialization of the run, appears an error:
"Error processing expression 'Density'.
The expression is invalid because: Dano is not available for use in this term"
I think this is because I didn't find anywhere to put an inital value of the av. Where can I initialize the av? If I can't, what can I do?
Thanks
Felipe Matos is offline   Reply With Quote
Old   February 3, 2011, 15:44
joey2007 is on a distinguished road
To be honest: i do not fully understand what you intend to do.
There are different kinds of av. If you chose the option transport equation it is possible to initialize. The type algebraic equation should depend on other variables, so it is not required to initialize.
Please do not forget: I am not paid for answering your questions.
Thousands of issues can cause a division by zero. Please do not capture a thread, with the argument: "I have the same issue ...."
joey2007 is offline   Reply With Quote
Old   February 3, 2011, 19:49
FM
My av is an Algebraic Expression. Like I said: Density = f (av) and av = f (T).
I think the problem is because the CFX initializes first its own variables (like Temperature, COndutivity, Density...); but my Density is a function of the av created, that is initialized olny after this primitive variables.
I don't know if the problem is this... Can anyone help?
Thanks
Old   February 4, 2011, 06:33
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
I can't check this but I suspect you cannot made density a function of a additional variable. There are only limited variables you can make density a function of. You will have to specify density as a direct function of temperature.
Old   March 28, 2011, 22:59
eric
armyou is on a distinguished road
Yeah, CFX11 Pre would show error information if additional variable is applied in density. In CFX12, although there is no any error or warning information in CFX pre, slover would be stopped because of the additional variable dependent density.
Glenn, do you think it is possible to solve this problem by using subroutine in CFX?
Actually I donot understand why CFX has such a limitation, is it because CFX can not initialize the density if additional variable is included?
armyou is offline   Reply With Quote
Thread Tools
Trackbacks are On
ADDITIONAL VARIABLES LIMITERS N.P CFX 5 December 1, 2011 08:47
what is boundary-only additional variables? frank CFX 0 September 6, 2008 22:11
additional variables' effect ariel CFX 9 April 2, 2008 00:41
user SUBROUTINE for additional variables Tuks CFX 0 November 8, 2005 03:09
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
