Home > Forums > CFX
Vacuum in the furnace
Old   February 8, 2011, 12:10
Default Vacuum in the furnace
Clif is on a distinguished road
Question about lesson Chapter 30: Coal Combustion, you want to specify a vacuum in the furnace.
In the example, the initial conditions are:
Through Coal Inlet air is supplied 1.015e-3 kg / s
Through Air Inlet air is supplied 1.035e-2 kg / s
At the outlet Outlet average static pressure = 0 Pa
How to set the boundary conditions (on Air Inlet and Outlet) to a pressure drop and air flow corresponded to the original value.
Tried a bunch of options obtained by either an error or a decision not to converge.
P.S. I do not know whether this will affect it at boundary conditions but in a furnace set - Buoyancy (for conv. heat).
Clif is offline   Reply With Quote
Old   February 8, 2011, 18:20
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Can you explain what you are trying to do? I do not understand your explanation.
ghorrocks is online now   Reply With Quote
Old   February 9, 2011, 04:04
OK.
How to create the boundary conditions on the in and out. (see illustration).
The model included treatment-Buoyancy.
Old   February 9, 2011, 06:32
I would set the In boundary to be a mass flow boundary at 1.035e-2 kg/s and the outlet to be a pressure opening at 0Pa. Use a reference pressure of 1atm-20Pa.
You cannot specify both the pressure and flow rate of an inlet boundary. This would over specify the boundary.
Thread Tools
Trackbacks are On
Assistance in Vacuum pump simulation enr_venkat CFX 5 November 20, 2012 12:50
Radiation in vacuum nitin CFX 0 July 6, 2009 01:49
Furnace curtains Marc FLUENT 0 April 18, 2007 08:01
Furnace Combustion wall problem Leigh FLUENT 2 December 11, 2006 16:01
Inclination of the furnace Clif CFX 1 October 4, 2006 05:48
