Input Parameter Value into Table
I've been varying a dimension of a system (length) to see the flow characteristics using Parameter setup in DesignModeler. So far I've had to create a line in CFD-Post, then change the line length manually to the parameter length I've changed. Then in the table, use =length()@Line 1
Is there a way I can directly input the parameter value to the table directly? |
