Moving Meshes in CFX
Old   February 11, 2011, 06:31
Default Moving Meshes in CFX
robsta01 is on a distinguished road
Hi
My problem is I need to simulate a flapping 2D flat plate in CFX. Therefore I need to be able to move the plate. I have only done stationary simulations before and do not know the best method to create this motion. I have thought of the possibility to allow the mesh to deform when the plate is moving but as my motion it quite great (30-35 degrees either side) I think the results I will get will be inaccurate.
Thanks for the help Rob
robsta01 is offline   Reply With Quote
Old   February 12, 2011, 05:36
If the motion is a rotation (or even just oscillating rotation) do it with rotating frames of reference. If the motion is translation you can use GGI interfaces. If there is a complex motion you need moving mesh. Moving mesh is explained in the CFX tutorial examples.
If the motion is too great for moving mesh alone you can include a remeshing step.
Old   February 12, 2011, 14:12
Yer is just rotation so I should hopefully be able to use rotating frames of reference. Do you know any specific tutorials which I'll find helpful?
Cheers Rob
Old   February 13, 2011, 05:58
No tutorials exist that I am aware of. There have been a number of posts on this topic on this forum, so do a search for them.
Old   February 15, 2011, 06:43
If I have to put a hinge or multiple hinges on the plate to attempt to model a fish's motion will the rotating frames of reference technique work?
Thanks Rob
Old   February 15, 2011, 16:44
You cannot nest multiple frames of reference.
You would have to post a drawing of what you propose for a more considered answer.
Old   February 16, 2011, 05:43
Hey I've attached a picture of a hinged aerofoil. My case is the same apart from I will be adding and varying the number hinges and I am simulating a flat plate not a foil. I wish to define the motion of each part of the plate such that I can simulate the motion of a fish. Would rotating frames of reference work in this case or is the motion too complex?
Cheers Robbie
Old   February 16, 2011, 16:06
You cannot nest rotating frames of reference.
You may be able to use one rotating frame of reference for the overall AOA, but the internal hinges will need to be done using moving mesh.
moving mesh, plate
Confirmation Needed on fvMeshSubset and Moving Meshes ngj OpenFOAM Programming & Development 1 September 17, 2010 08:06
Moving mesh settings in CFX 11.0 Anant CFX 3 December 13, 2007 10:18
How to specify the mesh moving mode in CFX Jemy CFX 2 August 27, 2007 20:04
Can CFX Automatically generate hybrid meshes? JJ CFX 0 August 28, 2003 21:18
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
