Temperatures on sides of the interface don't match
Old   February 15, 2011, 13:31
Smile Temperatures on sides of the interface don't match
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi CFX users,
I'm doing a complex heat transfer simulation. On the picture attached you can see a Solid-Fluid Interface Side 1 and 2, and the temperatures don't match. The left one seems to be correct, but the right one is probably wrong. I've attached the interface settings. The areas of the interfaces equals. What can cause this problem, or is it a post error?
Thanks in advance,
Attila
Attesz is offline   Reply With Quote
Old   February 15, 2011, 14:05
stumpy is on a distinguished road
There not supposed to match. One is showing the fluid temperature and the other the solid temperature.
stumpy is offline   Reply With Quote
Old   February 16, 2011, 04:56
Attesz's Avatar
Attesz
But they should match, because we talk about the same physical surface, or am I wrong? Is it a numerical thing?
On the other hand, the mesh sizes don't match on the sides. The solid interface has 3 times larger elements in the tangential direction than the fluid, however the axial directions match.
In the Post, the Temperature plotting is enough, or is there any trick to postprocess the results?
Thanks
Old   February 16, 2011, 09:59
The temperature of the physical surface would be the solid side temperature. In general the fluid flowing over that surface would not be at the same temperature as the solid surface.
Old   February 16, 2011, 10:40
Attesz's Avatar
Attesz
Ok, thank you, I tought about it and it is really unambiguous.
different temperature, interface, post error
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 22:50
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
