February 21, 2011, 10:57 |
Multiple probe points
Øyvind Larsen
Hi! I`m relative new to Ansys CFX and hope someone can answer my question.
I made a mesh in TurboGrid of an centrifugal compressor, and simulates this in CFX... works fine... but I want to insert 5 points through the blade passage at some coordinates/selected points and extract the values for pressure at these points so I can compare them to experimental results. I want these points to be constant so that I can run different simulations with for example varying volume flow, and read out pressure difference at these 5 points. Thanks! |
February 21, 2011, 20:36 |
Bharath kumar
Rep Power: 17 |
there is two way to do this.
1.If you want to do it after solving, then in cfx post you can create points and using function calculator you can get values. 2.If you want to do it in when solving itself, use source points in pre.define points using coordinates then create an expression like (probe(pressure)@sourcepoint1) and monitor values while solving. |
[snappyHexMesh] SnappyHexMesh - no layer added | bejbro | OpenFOAM Meshing & Mesh Conversion | 5 | February 1, 2020 20:05 |
Using Probe for part of a patch | ndr | OpenFOAM Running, Solving & CFD | 7 | April 4, 2019 06:26 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
ICEM clustering of mesh points and multiple edges | webhaw | CFX | 4 | July 25, 2007 16:29 |
