Home > Forums > CFX
Multiple probe points
Old   February 21, 2011, 11:57
Default Multiple probe points
Řyvind Larsen
oyvinl is on a distinguished road
Hi! I`m relative new to Ansys CFX and hope someone can answer my question.
I made a mesh in TurboGrid of an centrifugal compressor, and simulates this in CFX... works fine... but I want to insert 5 points through the blade passage at some coordinates/selected points and extract the values for pressure at these points so I can compare them to experimental results.
I want these points to be constant so that I can run different simulations with for example varying volume flow, and read out pressure difference at these 5 points.
Thanks!
oyvinl is offline   Reply With Quote
Old   February 21, 2011, 21:36
Bharath kumar
bharath is on a distinguished road
there is two way to do this.
1.If you want to do it after solving, then in cfx post you can create points and using function calculator you can get values.
2.If you want to do it in when solving itself, use source points in pre.define points using coordinates then create an expression like (probe(pressure)@sourcepoint1) and monitor values while solving.
bharath is offline   Reply With Quote
Thread Tools
Trackbacks are On
SnappyHexMesh - no layer added bejbro OpenFOAM Mesh Utilities 4 October 16, 2014 19:24
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Using Probe for part of a patch ndr OpenFOAM Running, Solving & CFD 5 November 8, 2009 04:47
BlockMeshmergePatchPairs hjasak OpenFOAM Native Meshers: blockMesh 11 August 15, 2008 07:36
ICEM clustering of mesh points and multiple edges webhaw CFX 4 July 25, 2007 16:29
