Invert control surface Ap??
Old   March 16, 2011, 12:53
Default Invert control surface Ap??
Sergio Croquer
sercro is on a distinguished road
Hi!!
I´m trying to simulate a Banki (cross-flow) hydraulic turbine, in stationary regime. It´s a multiphase simulation (water and air as IG).
After a few iterations, the solver apparently starts converging with certain stability. However, in an abrupt manner, the RMS values go all the way up, and the simulation stops with the following error on the .out file:
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Could not invert control surface Ap |
| Message: |
| Stopped in routine ASS_GLOBCS_IAP |
I´ve read that this can be solved by diminishing the physical timescale, but this didn´t work for me. I´ve also tried varying the meshes (structured and unstructured), meshes sizes, different timescales, with an stationary runner, monophase (just water)...
I´ve tried everything I could think of and I don´t find any solution to this. If someone could help me, I´d apreciate it very much.
Thanks in advance.
Sercro
sercro is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
[Commercial meshers] Tgrid control surface for diagnostic purposes josp OpenFOAM Meshing & Mesh Conversion 0 November 20, 2008 05:36
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
