Should I use Particle Transport Modeling for high gas volume fraction two-phase flow?
Old   June 5, 2019, 04:34
Red face Should I use Particle Transport Modeling for high gas volume fraction two-phase flow?
Terry
TerryNiu is on a distinguished road
Hi friends!
I am learning CFX and there are some basic problems that confuse me.
I'm going to simulate gas-liquid two phase flow whose gas volume fraction is very high. Like annular flow. The volume fraction of gas ranges from 90% to 99%.
Which model should I choose? Eulerian-Eulerian or Lagrangian Particle Tracking?
After reading the model guide, maybe Particle Transport Modeling is appropriate? i.e. Treat the liquid phase as dropltes?
I am going to observe the velocity profile of two phase after two phase mixture flow through a vane type swirler.
The structure of it like the picture I attached.
Could someone help me, thanks
TerryNiu is offline   Reply With Quote
Old   June 5, 2019, 05:36
Gert-Jan
Gert-Jan will become famous soon enough
If the liquid volume fraction is 1%, then LPT is the way to go. But if you have annular flow with 10% liquid volume fraction, then Euler might be better.
It all depends on the question that you are trying to answer when modeling CFD. Can you tell us more?
Gert-Jan is offline   Reply With Quote
Old   June 5, 2019, 06:43
Smile
Terry
Thanks your reply.
Old   June 5, 2019, 07:07
Gert-Jan
Difficult problem. Main uncertainties are with the droplets hitting the wall. Will they stick, coalescence, break up, re-entrainment, rivulets, etc. And if they re-entrain, what wil lthe droplet size be.....??
Nevertheless, if you are only interested in the velocity profile, then you could opt for LPT.
If you are interested in where the liquid ends up, then Euler might be better. Maybe it is even better to use a model that can handle both at the same time. Then mass can go from LPT to Eu, vice versa. These are available in fluent or Star-CCM+. Not in CFX.
Old   June 5, 2019, 07:40
Terry
Thanks for your analysis and good advice, I think i should try the both model and find is there any differences.
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
Fluent Limitations tymcme FLUENT 6 August 1, 2022 08:50
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
Is it possible that multi-phase flow shows gradation of volume fraction? kjh9537 Fluent UDF and Scheme Programming 0 June 23, 2017 14:16
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 07:09
