-   -   No Slip Wall with Fixed Temperature Boundary Condition (http://www.cfd-online.com/Forums/cfx/85931-no-slip-wall-fixed-temperature-boundary-condition.html)
Karkoura March 9, 2011 19:34
I am using CFX to model a 3D turbine cascade. My ultimate objective is to compute the heat transfer coefficient distribution at the blade surface.
The flow is subsonic compressible so I am using "Total Energy" and "Air Ideal Gas" for the working fluid.
I am also using the SST turbulence model, with an O-grid mesh around the blade, and a small distance of the first node away from the wall in order to obtain a yplus of around 3.
Since I would like to compute the heat transfer coefficient distribution at the blade surface, I defined the blade walls, to be no slip and applied a fixed temperature of 296K.
However, as I post-process the simulation and export the variables at the blade loading line, I do not obtain a temperature of 296K at the blade wall.
How can that be since I did specify a temperature?
I would really appreciate any comments you may have. I would also benefit from the experience of those who did heat transfer calculations in a turbine cascade.
Thank you in advance
ghorrocks March 9, 2011 19:37
If you correctly defined a fixed temperature then they have the temperature you defined. Either you set it up wrong or you are post processing it wrong.
Karkoura March 9, 2011 19:44
Dear Glenn,
Thanks for the answer.
First of all there are not so many ways of specifying a temperature at the blade. Under "Boundary Details" > "Heat transfer" option, I choose "Temperature" and apply a fixed temperature of 296K.
So it seems plausible to me that I am post processing it wrong. I have a question concerning that. What is the "Blade Loading Line" in CFX?
You see what I do in CFD post in that I go to "
File > Export
for the Location, I choose "Blade Loading Line"
for the Boundary Data, I choose "Current"
then I select all the variable I need (of which the temperature) and I save it to a .csv file.
Are you familiar with this procedure? Would you know of any other way for computing variables at the blade surface, at a certain span location?
Thanks
stumpy March 10, 2011 09:54
You're probably exporting conservative values rather than hybrid values. See the CFX doc for the difference.
Karkoura March 10, 2011 12:05
Dear Stumpy,
You are correct. I was exporting conservative values! Thank you!
Karkoura March 10, 2011 16:28
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade
CFD Post outputs data for two particular variables. The "wall heat flux (q) " and the "wall heat transfer coefficient (h) ". From the CFX manual, I understand that these two are related by:
h = q / (T_wall - T_adjacentwall)
These values are very high and not in agreement with experimental data.
I tried to compute the wall heat flux myself by using the following:
q = -k * (Twall - Tadjacent wall) / y
where
k is the thermal diffusivity
Twall is the wall temperature (which I had specified as a boundary condition)
Tadjacent wall is the temperature of the first node away from the wall.
and
y is the distance of the first node away from the wall to the wall itself (this value I defined when I was creating the O-grid mesh around the airfoil in ICEM CFD)
Still I see that the variable are underpredicted compared to experimental data and the trend of heat transfer distribution with streamwise direction on the blade surface is not smooth and fluctuating.
I would appreciate any comments and knowledge you can share about computing the heat transfer coefficient in compressible flow.
Thank you so in advance.
stumpy March 10, 2011 17:46
If you are comparing to experimental data then their HTC is likely based on a reference temperature other than Tadjacent wall. You should use the expert parameter "tbulk for htc" to set a reference temperature for the HTC calculation.
Karkoura March 10, 2011 18:23
Do you know where I can specify tbulk?
