Temperature at specific time steps
Hi all,
I am trying to get a Expression done that gives me the difference of the last 3 or 4 Temperature peaks in a transient simulation, and I want to use this expression in the Interrupt Control. I know at what times the peaks are, so I can get the time step numbers. I can also create a script to get those values, but only after the simulation run is finished. What I need is a expression like: 0.01 [K] > MaxT@Timestep(81) - MaxT@Timestep(61) I know "@Timestep(81)" doesn't exist, but I am looking for something that works like that. Basically my simulation has periodic peak points. Those peak points are settling down at a certain temperature. When this temperature at the peaks has a change of less then 0.01 [K] I want to interrupt the simulation. Hope somebody can help me there??? Regards, Alex http://dl.dropbox.com/u/15545838/peaks.jpg |
CFX Expressions cant remember prior values while in solution (you can get fancy and delay updating a variable so that you can get current timestep value - previous timestep value numbers but that is about the extent you can do in CEL). You will need user fortran.
Thanks for the reply.
I haven't used Fortran yet, but looks like I need to get into it. Am I assuming right, that I can play with variables and manipulate the simulation process? |
You can do pretty much anything you like with user fortran. But be warned, it is not straight forward.
If you want to implement a simple function as you describe you could do it using a separate file (maybe a cron job) which monitors the output of your monitor point and if triggered runs the cfx5stop command. I suspect this will be much easier to implement than the fortran option. |
| All times are GMT -4. The time now is 00:04. |
