how to define user variables
Hello everyone,
I want to write a user variable in CFX-pre for shear stress since there is only shear strain rate available in CFX-post: Shear stress = shear strain rate x dynamic viscocity Is there an example for that? Thanks, Wendy |
user variabels
Hi Wendy,
define your expression in CFX-Pre, after solving read in the result file in CFX-Post and define there a user scalar variable which references the expression defined in Pre. best regards Matthias |
Hi matthias,
I would happy if you could tel me how we can make user defined variables in CFX post. I would really appreciate. Thanks |
user variable
Dear soni_sth,
for example if you are analyzing a pipe flow, you could add scalar or vector user definied variables into CFX-Post. For example i added "dynamic pressure" - select "Variables" tab in CFX - Post - right click into "Variables" white window - select new or edit in command - the data you want to use must be there, i mean a variable from solution or an expression defined in CFX - Pre in the command edior your additional variable "dynamic pressure" should look like this: USER SCALAR VARIABLE: dynamic pressure Boundary Values = Conservative Calculate Global Range = On Expression = 0.5*Fluid.Density*(Fluid.Velocity)^2 Recipe = Expression Variable to Copy = Pressure Variable to Gradient = Pressure END hope this is what your are looking for, best regards MAtthias |
Thanks a lot Matthias.
