Home > Forums > CFX
interpolate - previous result file in DP
Old   March 15, 2011, 23:56
Default interpolate - previous result file in DP
turbotel is on a distinguished road
i'm simulating turbocharger's turbine side and RPM is 195k.
i couldn't get the convergenece at 195k RPM so 1st with 10k and slowly i'm increasing the rpm.
so i've created a parameter set in workbench.
design point 1- RPM: 10000 mass flow:xxx
design point 2 - RPM: 50000 mass flow:yyy
like that i've created a 6 design ponts and solved the problem.
for DP2 solver take DP1's results - it's ok but for DP3 it take DP1's result file.
hope understood my problem, now...
How can i change these setting?
thank you
turbotel is offline   Reply With Quote
Old   March 18, 2011, 07:16
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Change what settings?
Old   March 18, 2011, 07:20
assigning previous run's result file.
automatically in workbench
Thread Tools
Trackbacks are On
OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 electrosin OpenFOAM Installation 39 July 1, 2014 07:55
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 08:11
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
