Help! Cfx error #00110027
Error in subroutine FNDVAR : Error finding variable DENSAT_FL2 GETVAR originally called by subroutine cal_DIAM +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine GV_ERROR | | | | | | | | | | | +--------------------------------------------------------------------+ I was trying to do wall boiling modelling for water. Anyone knows what is wrong when you have the above error message? Thanks! |
DENSAT_FL2
Guess DEN --> Density SAT --> Saturation FL2 --> Fluid 2 Check your setup for errors with respect to fluid properties |
Hi joey2007,
thanks for the enlightenment, i will try to check again. but i am actually using the material/fluid (water & water ideal gas) from the CFX database... by what chance would it has gone wrong? you have any idea? thanks :) |
Unlikely but it might be wrong. I found a bug way back in CFX 4.2 where the built in material properties for air ideal gas was wrong a few decimal points in.
Much more likely you are not specifying it correctly. If you are running a compressible simulation, is the material "water" the right one to use? |
Did you find solution to this problem yet? |
