March 3, 2011, 03:40 |
a mesh motion question
John
Rep Power: 15 |
Dear all,
I am working on a fsi case. The fluid model can work well before mesh motion is turned on. But if I used mesh motion, even without fsi, it got overflow quickly. Even if I use the result of static mesh case as the initial condition of mesh motion case, it still can not work. Please help me if anyone know how to solve this problem. Thank you so much! John |
March 3, 2011, 17:45 |
Rep Power: 143 |
Some details of what you are doing might be useful......
March 3, 2011, 21:34 |
John
Rep Power: 15 |
There are two domains in my fluid model: water and porous. I used mesh motion in water domain. The problem is, even no fsi, just the fluid model itself, it gets overflow all the time. In the output file, all the mesh deformations are 0, which means the mesh is exactly the same with static mesh case.
March 6, 2011, 16:59 |
Rep Power: 143 |
So you are saying that you turn mesh motion off and it converges but you turn mesh motion on, but specify zero displacement it diverges?
March 15, 2011, 21:24 |
John
Rep Power: 15 |
March 16, 2011, 10:54 |
Edmund Singer P.E.
Rep Power: 20 |
Make your water slightly compressible.
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
Dynamic moving mesh | Pei-Ying Hsieh (Hsieh) | OpenFOAM Running, Solving & CFD | 64 | June 7, 2012 10:04 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Mesh motion Hex cells vs tets | kev4573 | OpenFOAM Running, Solving & CFD | 6 | December 13, 2007 14:37 |
ICEM 10 mesh question | DAK565656 | CFX | 6 | May 8, 2007 12:16 |
