April 18, 2023, 14:25 |
Data for each time step non monitored
zaid
Rep Power: 3 |
Hi everyone,
Is it possible to access data for each time step in CFX Post (in my case the average pressure at the inlet) if I have not monitored this variable in CFX-Pre ? If so, how ? Do I have to write a CEL file ? Thanks and have a good day all |
April 18, 2023, 18:22 |
Rep Power: 143 |
You can do CEL calculations in CFD-Post. Have a look at the function calculator. You can also define expressions and variables.
April 19, 2023, 11:43 |
Rep Power: 32 |
1 - create a chart
2 - In the General Tab: select a XY-Transient 3 - In the Data Series Tab: for the series Data Source select Expression 4 - In the Expression widget type your average: areaAve(Pressure)@MyLocation 5 - Apply
post processing |
Display Modes | |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 02:05 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
