EDM Coefficients A and B
Old   March 19, 2011, 08:21
Default EDM Coefficients A and B
HurricaneHenry is on a distinguished road
i have some problems while modelling a combustion chamber. I use the coupled Eddy Dissipation Model (EDM) and Finite Rate Chemistry, because Eddy Dissipation Concept (EDC) ist not available in CFX12. The combustion chamber has two inlets, one with fresh air and one with a mixture of H2/CO/CH4/CO2/N2/O2. As reaction mechanism I use a global 3step Westbrook Dryer mechanism with 3, only forward, reactions for burning CH4, CO and H2. In Every reaction, arrhenius with temperature PDF is used (Don't know if it's better than normal arrhenius).
The aim is, to determine the leftover of CO at the outlet, but it's problematic, because during the simulation H2/CO/CH4 is fully burned. The mass fraction at the outlet of CO is 0.00000. So there's nothing to determine. In the simulations i used the standard values for the coefficients of the reactant and product limiters A and B in the Eddy Dissipation Model (A=4, B=-1,0 ?). In the tutorial "simulating a gas chamber" the values A=4,0 and B=0,5 are used.
Can anybody recommend me some Values for the coefficients of the reactant and product limiters A and B in the Eddy Dissipation Model for homogeneous gas phase combustion? What's about Chemical Time Scale?
Greetings,
Hurricane
HurricaneHenry is offline   Reply With Quote
cfx, coefficients, combustion, edm
Calculate aerodynamic coefficients with openfoam using only opensource programs Xwang OpenFOAM 20 May 20, 2016 11:26
lift and drag coefficients around a ground vehicle Pedro CFX 3 September 5, 2012 18:31
Blottner Coefficients f_sizer Main CFD Forum 0 August 26, 2010 07:03
Computing aerodynamic coefficients on bidimensional sections in 3D problems Aragon FLUENT 0 July 22, 2009 04:07
tube bank inertial resistance coefficients Brian FLUENT 0 September 8, 2004 09:04
