March 19, 2011, 23:05 |
overflow during writing result
just got frustrated with overflow problem. The simulation looks alright during solving and is converging. But once the simulation is terminated or to write a backup result file, it gives overflow error and crashes. The simulation is a SST turbulence, fluid-solid conjugate simulation. The mesh quality is not good, I got a A negative SECTOR (ERROR #002100011) error, but simulation can run. I have no idea how to fix it because the error happens during writing results instead of a typical divergence. What should I check? thanks a lot +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Floating point exception: Zero divide | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine C_FPX_HANDLER: | +--------------------------------------------------------------------+ |
March 20, 2011, 13:11 |
You have to improve the mesh.
- - - - - ------------------------------------------------------------------------ Please do not forget: I am not paid for answering your questions. Thousands of issues can cause a division by zero. Please do not capture a thread, with the argument: "I have the same issue ...." |
March 21, 2011, 08:11 |
problem solved. I traced to the location where the CFX indicates sector negative volume, and manually corrected local mesh. Then it went alright. Thanks for any attention.
Comparison the airfoil 0012 experimental result and simulation result | harrislcy | FLUENT | 30 | August 29, 2013 10:27 |
Read Result Files or User Defined Result | Aquilaris | ANSYS | 0 | February 9, 2011 05:25 |
Solution variables goes outside upper limit -how to localize fatal overflow occurance | Dimone | CFX | 2 | January 21, 2011 06:35 |
In a distance above the ground, my LES result is not good | panda60 | OpenFOAM | 2 | January 22, 2010 07:52 |
overflow when interpolate initial result | richard | CFX | 1 | June 11, 2008 07:36 |
