Heat Transfer between two different phase fluids
Old   March 20, 2011, 08:55
Default Heat Transfer between two different phase fluids
jjj
Julian Nash
jjj is on a distinguished road
hi i was wondering if anyone could help me.
i'm busy with an analysis for gas cooling uptakes of a furnace. Im struggling to get the analysis to run, ive created 3 domainds one for the water & another for the steel & another for the gas. ive also inserted all my interfaces between the surfaces. but it does not want to solve, it gives me the error "ERROR #001100279 has occured in subrutine ErrAction
MESSAGE :
>Floating point exeption : Overflow.
can someone please advise me on wat to check/change.
If anymore information is required just let me know i'll be more then willing to put up some screen shots or watever is needed...
regards
julian
jjj is offline   Reply With Quote
Old   March 20, 2011, 21:03
Your simulation has diverged. You need to improve the numerical stability. Try to fix any boundary or physics problems, smaller time steps, tighter convergence, better mesh quality.
Old   March 21, 2011, 04:19
jjj
Julian Nash
hi i did end up changing the mesh to a higher quality. But now it gives me the error:
| ERROR #002100012 has occurred in subroutine cVolSec. |
| Message: |
| A negative ELEMENT volume has been detected. This is a fatal |
| error and execution will be terminated. The location of the first |
| negative volume is reported below. |
| Volume : -0.1104E-10 |
please advise?
thanks
Old   March 21, 2011, 13:56
joey2007 is on a distinguished road
CFX assembles control volumes from your mesh. Some of these volumes are negative. The mesh quality is still too bad.
In order to find the region load the def-file into post, generate a point and copy the given location to the coordinates. It will show you where the negative volume is. Go back to meshing and improve it there.
Please do not forget: I am not paid for answering your questions.
Thousands of issues can cause a division by zero. Please do not capture a thread, with the argument: "I have the same issue ...."
joey2007 is offline   Reply With Quote
question about Heat transfer between two phases with VOF model sooroo3 FLUENT 0 February 15, 2011 03:24
what approach for direct mixing fluids with heat transfer and phase change? hennas Main CFD Forum 0 June 9, 2009 15:44
heat transfer in two-phase flow Leonid Fromzel CFX 0 April 8, 2008 05:57
Heat Transfer problem (two different fluids) Jon FLUENT 5 February 20, 2008 06:56
phase transforming with heat transfer Danual FLUENT 5 June 3, 2003 12:38
