-   -   Expression for physical timescale (http://www.cfd-online.com/Forums/cfx/86383-expression-physical-timescale.html)
xyq102296 March 21, 2011 14:55
From the help file under physical time scale chapter,
"It is often necessary to alter the physical time scale for buoyancy driven flows in order to achieve convergence."
So max physical time scale will be : delta(tmax)=(dL/(B*g*deltaT))^0.5
here L is a length scale associated with the vertical temperature gradient;
deltaT is the temperature variation in the fluid; B is the thermal expansivity of the fluid; g is the gravity
So an expression for the physical time scale is needed.
But for a 3D model with non-uniform mesh ,how to define the CEL of the physical time scale? how to define dL here? deltaT is radial or vertical temperature difference?
ghorrocks March 21, 2011 20:16
The equation just gives a first guess estimate. If you could not be bothered working it out you can just make a guess (1s is a good starting point) and just go from there. Obviously a bit of trial and error and not very efficient but should be OK for most cases.
Often the time scale size makes little difference in steady state simulations.
xyq102296 March 22, 2011 03:33
From the original sentence, "it's often necessary to alter the physical timescale", so I do not need to use a CEL language to alter it from time to time? just use a fixed number for example 1s?
ghorrocks March 22, 2011 07:53
Yes, just a fixed number. I change it while the simulation is running (using solver manager) so I can adjust the timestep easily and adjust it if it looks too big or small without having to restart.
xyq102296 March 22, 2011 09:06
so I guess you use "Edit Run in Progress" under "Tool" Menu.
During the running, I found RMS of U,V,W-Mom and H-energy is one order higher than MAX, for example rms=2.5e-06 and max is 1.4e-04, how shall I modify the physical timescale?
xyq102296 March 22, 2011 09:14
1 Attachment(s)
the location of high residuals is not very far from the place I am interested in, so I guess this is a local problem. WHile from the attached graph, I do not have poor grid quality, so what kind of step can I do to fix this problem?
ghorrocks March 22, 2011 22:20
Do a sensitivity study. Do a simulation using your current convergence, and a second converged to maybe a factor of 10 better. Did values of interest to you change significantly? If not then your current convergence is probably OK.
xyq102296 March 23, 2011 03:59
Now my convergence criteria is 1e-06, so your suggestion is getting to 1e-05 and see the result?
I have done the grid independent study, the mesh is ok.
And from the help file, it says"When you are having problems converging, you can check RMS and MAX residuals"
I can converge to RMS 1e-06, while my MAX residual is more than one order higher than RMS, so is this a local problem or we can just neglect it since its convergence
Thank you
ghorrocks March 23, 2011 18:46
Yes, you can also compare against a run with looser convergence. The aim is to see whether convergence makes any difference.
xyq102296 March 24, 2011 04:04
The temperature and velocity distribution shape are the same, only I got slightly higher temperature in lower convergence criteria. So do you have any comments on this. I can converge while still there is one order higher between RMS and MAX residual, does it matter? THe MAX residual show near the region of interest
ghorrocks March 24, 2011 21:33
I cannot comment on this - it is you to decide. Is the difference between the tight and loose convergence significant for the results you are interested in. Only you know what you are interested in.
