Anisotropic thermal conductivity in an insulated stranded coil
Old   April 4, 2011, 05:17
Cool Anisotropic thermal conductivity in an insulated stranded coil
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi CFX users,
I'm modeling an electromotor inner fluid domain including the heat source solid domains. The main problem is that there are little air gaps between the copper conductors (little circles nearby) and they are insulated by varnish. So towards the conductors the heat transfer coefficient is about the value of the copper, but in the orthogonal directions it is reduced because of the air gaps and the insulation.
My first idea is to write to the support to help me how to model the anisotropic thermal conductivity via CCL commands as I read in other topics here.
But I'm interested in your other suggestions about the modelling of this problem.
Thanks in advance,
Attila
Attesz is offline   Reply With Quote
Old   April 4, 2011, 09:46
Edmund Singer P.E.
singer1812 is on a distinguished road
Contact support.
This can be done by modifying the material properties in CEL. The limitation is that the orthotropic material properties must be aligned with either the Global Cartisian Coord System, or Global Cylindrical System, so your body has to be aligned right and be of a geometry allows this limitation.
singer1812 is offline   Reply With Quote
Old   April 4, 2011, 10:27
Attesz's Avatar
Attesz
Thanks Edmund, fortunately my geometry is aligned with the GCS, I thought that this is necessary. I'm waiting for the support.
On the other hand, am I right with the approach of the modelling?
Old   April 4, 2011, 10:36
Edmund Singer P.E.
No idea.
I am not clearly picturing what you are trying to model. If you are just determining an HTC to use as a BC, then I wouldnt think you need to use ortho props at all.
On the other hand, if you are trying to model thermal gradients within the solid domain, then perhaps yes.
Old   April 4, 2011, 11:08
Attesz's Avatar
Attesz
Yes, I'm trying to model this. Thanks!
anisotropic, ccl, conductivity, solid, thermal
thermal conductivity --> anisotropic material val46 OpenFOAM 17 February 9, 2023 13:03
Anisotropic thermal conductivity suitup OpenFOAM 1 July 5, 2019 09:27
Anisotropic Thermal Conductivity Saturn CFX 4 January 30, 2007 12:34
anisotropic thermal conductivity Lugdi Siemens 0 January 15, 2007 08:03
anisotropic thermal conductivity, please help! GBLiu FLUENT 0 June 8, 2006 21:08
