April 1, 2011, 08:20 |
Problems with 3D
Rep Power: 15 |
Hi! Up till now I have been doing simulations in CFX with only 1 cell in the third coordinate direction. My results were pretty good so i wanted to check what would happen if I extend my model so as to make it three dimensional. I increased the thickness and added more cells in this direction. Using the same setup as before (timestep, accuracy ...) I have tried running this simulation but it always crashes on the first timestep in the first coefficient loop (floating point exception: overflow). Any ideas on what I should do to enable this 3D run?
April 1, 2011, 08:29 |
#2 | |
Raashid Baig
Rep Power: 16 |
Just the first step check - are you sure about the integrity of your 3D mesh ? I mean do you see any error or warning messages for the new mesh ? |
April 1, 2011, 10:56 |
Rep Power: 15 |
No, the mesh is is fine. I get no warnings or anything like that. It just crashes straight away. Should I change the setup for the 3D mesh or should it work with the same settings as before?
April 3, 2011, 06:43 |
Rep Power: 143 |
Please post the output file around where it crashes.
April 5, 2011, 05:02 |
Rep Power: 15 |
Hi! The error looks like this:
+--------------------------------------------------------------------+ | Convergence History | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Writing transient file 0.trn | | Name : Transient Results 1 | | Type : Selected Variables | | Option : Time Interval | +--------------------------------------------------------------------+ ================================================== ==================== | Timestepping Information | ---------------------------------------------------------------------- | Timestep | RMS Courant Number | Max Courant Number | +----------------------+----------------------+----------------------+ | 5.0000E-03 | 0.39 | 7.60 | ---------------------------------------------------------------------- ================================================== ==================== TIME STEP = 1 SIMULATION TIME = 5.0000E-03 CPU SECONDS = 2.666E+01 ---------------------------------------------------------------------- | SOLVING : Wall Scale | ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | Wallscale-Bulk | 0.00 | 2.2E-05 | 1.1E-04 | 43.0 6.1E-01 ok| +----------------------+------+---------+---------+------------------+ | Wallscale-Bulk | 3.25 | 7.1E-05 | 2.2E-03 | 33.6 9.0E-02 OK| +----------------------+------+---------+---------+------------------+ | Wallscale-Bulk | 0.62 | 4.4E-05 | 1.6E-03 | 29.0 9.7E-02 OK| +----------------------+------+---------+---------+------------------+ | Wallscale-Bulk | 0.87 | 3.8E-05 | 1.5E-03 | 29.0 8.8E-02 OK| +----------------------+------+---------+---------+------------------+ | Wallscale-Bulk | 0.84 | 3.2E-05 | 1.2E-03 | 29.0 8.3E-02 OK| +----------------------+------+---------+---------+------------------+ | Wallscale-Bulk | 0.90 | 2.9E-05 | 1.1E-03 | 24.3 9.8E-02 OK| +----------------------+------+---------+---------+------------------+ ---------------------------------------------------------------------- COEFFICIENT LOOP ITERATION = 1 CPU SECONDS = 7.928E+01 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Floating point exception: Overflow | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ Details of error:- ---------------- Error detected by routine POPDIR CRESLT = ILEG Current Directory : /FLOW/NAMEMAP |
April 5, 2011, 18:43 |
Rep Power: 143 |
Start with a smaller initial time step or a more representative initial condition. This assumes you have set the simulation up correctly, of course.
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
Help required to solve Hydraulic related problems | aero | CFX | 0 | October 30, 2006 11:00 |
Some problems with Star CD | Micha | Siemens | 0 | August 6, 2003 13:55 |
Using Fluent for Geophysical Problems | Hassid Samuel | FLUENT | 0 | February 23, 2001 06:04 |
