cfx5post in batch mode on "graphics-less" Linux |
April 8, 2011, 17:48 |
Frank D.
I am getting the following error "cannot connect to X server" while running "cfx5post -batch xxx.cse" from command line. The OS is RHEL 4 and has no graphics card, and thereby the DISPLAY environment variable is not set. I have also tried "cfx5post -batch xxx.cse -graphics mesa" without success.
Does cfx5post need a graphics display while running in batch mode??? Frank D. |
April 10, 2011, 21:16 |
Rep Power: 19 |
unfortunately yes.
the way we got around this to run all our macros in batch mode was to create a virtual frame buffer. Install xvfb http://en.wikipedia.org/wiki/Xvfb configure (even suggest to create an init.d script so it starts all the time). Ensure you set a reasonable resolution and color depth. then use the -display # switch for cfxpost. If I recall, it stems from Qt and some quick of its system. |
April 12, 2011, 11:26 |
Rep Power: 19 |
Found my documentation
Detailed for Suse, but should be similar for RH. Enjoy Description Xvfb is a virtual frame buffer to create an X display. Installation
Boot script Xvfb script Xvfb Settings Display Number: 71 X Auth File: /etc/Xvfb.auth Screen Setting: screen 0 2048x2048x24 Memory Mapped File: /tmp/Xvfb_screen0 Log File: /var/log/Xvfb_X71.log Lock File: /tmp/.X71-lock Code:
#!/bin/sh # # # /etc/init.d/xvfb # and its symbolic link # /usr/sbin/rcxvfb # ### BEGIN INIT INFO # Provides: Xvfb # Required-Start: network nfs # Should-Start: # Required-Stop: network # Should-Stop: # Default-Start: 3 5 # Default-Stop: # Short-Description: Xvfb daemon, provides virtual frame buffer # Description: Start Xvfb # Primarily used for batch processing because # CFX and Ansys require an X Display. ### END INIT INFO # # Check for missing binaries (stale symlinks should not happen) # Note: Special treatment of stop for LSB conformance XVFB_BIN=/usr/bin/Xvfb test -x $XVFB_BIN || { echo "$XVFB_BIN not installed"; if [ "$1" = "stop" ]; then exit 0; else exit 5; fi; } # Decided not to source a config file # Left the code just incase # Check for existence of needed config file and read it #XVFB_CONFIG=/etc/sysconfig/xvfb #test -r $XVFB_CONFIG || { echo "$XVFB_CONFIG not existing"; # if [ "$1" = "stop" ]; then exit 0; # else exit 6; fi; } # # Read config #. $XVFB_CONFIG # The auth file is a plain text file with only "localhost" listed. XVFB_DISPLAY=71 XVFB_AUTHFILE="/etc/Xvfb.auth" test -r $XVFB_AUTHFILE || { echo "$XVFB_AUTHFILE not existing"; if [ "$1" = "stop" ]; then exit 0; else exit 7; fi; } XVFB_SCREEN="-screen 0 2048x2048x24" XVFB_MMAP="/tmp" XVFB_LOG="/var/log/Xvfb_X$XVFB_DISPLAY.log" XVFB_ARGS=":$XVFB_DISPLAY -auth $XVFB_AUTHFILE $XVFB_SCREEN -fbdir $XVFB_MMAP" # Shell functions sourced from /etc/rc.status: # rc_check check and set local and overall rc status # rc_status check and set local and overall rc status # rc_status -v be verbose in local rc status and clear it afterwards # rc_status -v -r ditto and clear both the local and overall rc status # rc_status -s display "skipped" and exit with status 3 # rc_status -u display "unused" and exit with status 3 # rc_failed set local and overall rc status to failed # rc_failed <num> set local and overall rc status to <num> # rc_reset clear both the local and overall rc status # rc_exit exit appropriate to overall rc status # rc_active checks whether a service is activated by symlinks . /etc/rc.status # Reset status of this service rc_reset case "$1" in start) echo -n "Starting Xvfb on DISPLAY=:$XVFB_DISPLAY" # Remove the old log file rm -f $XVFB_LOG ## Start daemon with startproc(8). If this fails ## the return value is set appropriately by startproc. /sbin/startproc -l $XVFB_LOG $XVFB_BIN $XVFB_ARGS # Remember status and be verbose rc_status -v ;; stop) echo -n "Shutting down Xvfb " ## Stop daemon with killproc(8) and if this fails ## killproc sets the return value according to LSB. /sbin/killproc -TERM $XVFB_BIN # Remember status and be verbose rc_status -v ;; restart) ## Stop the service and regardless of whether it was ## running or not, start it again. $0 stop $0 start # Remember status and be quiet rc_status ;; status) echo -n "Checking for service Xvfb " ## Check status with checkproc(8), if process is running ## checkproc will return with exit status 0. # Return value is slightly different for the status command: # 0 - service up and running # 1 - service dead, but /var/run/ pid file exists # 2 - service dead, but /var/lock/ lock file exists # 3 - service not running (unused) # 4 - service status unknown :-( # 5--199 reserved (5--99 LSB, 100--149 distro, 150--199 appl.) # NOTE: checkproc returns LSB compliant status values. /sbin/checkproc $XVFB_BIN # NOTE: rc_status knows that we called this init script with # "status" option and adapts its messages accordingly. rc_status -v ;; *) echo "Usage: $0 {start|stop|restart|status}" exit 1 ;; esac rc_exit |
April 12, 2011, 16:47 |
Frank D.
Thanks mjgraf!
Using xvfb-run (wrapper around xvfb) solved the problem. Frank D. |
Running Ansys in BAtch Mode | kuleuvenstudent | ANSYS | 1 | October 18, 2017 12:11 |
fluent 12.1, batch mode in linux | sakalido | FLUENT | 13 | September 27, 2017 08:55 |
making animation in batch mode in linux | rocklove | FLUENT | 0 | July 10, 2010 02:17 |
CFX5Post error in batch mode with Perl | windhair | CFX | 2 | March 20, 2007 05:41 |
Prosurf in batch mode | Dhruv | Siemens | 1 | September 19, 2005 18:02 |
