April 12, 2011, 13:11 |
Static pressure problem
Kooky
Rep Power: 15 |
Dear All,
I was applying the boundary condition, the mass flow rate at the inlet surface and static pressure is zero at the outlet surface. So, I was checking the static pressure at the outlet surface in CFX post, it did not the same value. Anybody knows how to obtain the same value. Total pressure is sum of static and dynamic pressure. I measured the total pressure and dynamic pressure at the outlet surface. Is that correct for predicting the static pressure? Thank you for your respond |
Pressure averaging at the outlets. | KM | CFX | 6 | April 1, 2021 06:28 |
fprint problem | MASOUD | Fluent UDF and Scheme Programming | 5 | October 30, 2011 16:08 |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 17:19 |
problem with static pressure | Nina | FLUENT | 3 | February 28, 2008 13:08 |
Static vs Total Pressure | Alfonso Ferrandez | FLUENT | 2 | May 23, 2000 08:53 |
