April 26, 2011, 08:59 |
interface heat transfer
Rep Power: 15 |
Hello everyone.
I have a question about heat transfer between two solid domains. I need to compare two cases. First one with no heat transfer between two domains and second one with heat resistance on the surface. Is it right when I don't check the box in "additional interface model" (heat transfer) and no heat transfer is desired?? Thanks a lot for any question |
April 26, 2011, 12:47 |
Rep Power: 17 |
The default for the interface is ideal contact. What the additional model does can be seen, when you play around with the options.
- - - - - ------------------------------------------------------------------------ Please do not forget: I am not paid for answering your questions. Thousands of issues can cause a division by zero. Please do not capture a thread, with the argument: "I have the same issue ...." |
Display Modes | |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Interface Heat Transfer | george | CFX | 4 | October 14, 2008 23:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
