Solid Body rotating
Old   April 9, 2011, 12:31
Unhappy Solid Body rotating
Kristofer Estellen
Svidd is on a distinguished road
I am new to this forum, and I hope, that someone would help me with little problem. How can I specify rotational velocity using CEL on a hemisphere?
Svidd is offline   Reply With Quote
Old   April 10, 2011, 06:47
RotationAngle = omega * time
omega is your rotational velocity, and set your hemisphere angle to RotationAngle.
Old   April 10, 2011, 08:29
Kristofer Estellen
I appreciate your responde, but can you tell me, how can I set hemisphere angle to my expression?
Old   April 10, 2011, 22:24
You have not yet said what you are trying to do. Are you using an immersed solid, rotating frame of reference or moving mesh approach? They are all different.
Old   April 11, 2011, 00:11
Kristofer Estellen
I tried to use rotating frame of reference, it seems to be the simplest way, but I still don't really understand how can I set one.
Old   April 11, 2011, 06:24
You still have not explained what you are trying to do. Can you post an image?
Old   April 11, 2011, 11:57
Kristofer Estellen
http://img861.imageshack.us/i/93422970.jpg/
As simple as that. I need to set this hemisphere rotating around Z axis, and then set an airflow around it, to determine what's going to happen with the flow depending on velosity of rotation
Old   April 11, 2011, 18:43
In that case no need for any of that. Just put a tangential velocity on the hemisphere surface. You will need to define a CEL expression to evaluation the tangential velocity as a function of XYZ location but that should be easy.
This is then a simple analysis with no moving mesh, rotating frames of reference or anything tricky. Easy.
Old   April 12, 2011, 00:27
Kristofer Estellen
So I need to use wall boundary for hemisphere surface, and then give it tangential velocity?
Therefore, I understand, how to set a tangential velocity ac a function of XYZ location, but I dont understand what to do with time dependence.
Old   April 12, 2011, 07:29
What time dependence? Is the angular velocity changing with time?
Old   April 12, 2011, 09:55
Kristofer Estellen
well, if I'll write this expressions:
R=(x^2+y^2)^(1/2)
f0=asin(x/R)
X1=R*sin(f0+RotationAngle)
Y1=R*cos(f0+RotationAngle)
RotationAngle=Omega*Time
That will do the right thing?
and no, angular velocity is constant
Old   April 12, 2011, 18:37
I think you have missed the point. We are modelling in a Eularian frame so what the fluid sees at any point on the surface is just a constant tangential velocity. There is no time component.
Re-meshing a deformable solid body in a fluid brashear CFX 6 December 12, 2011 11:13
Rigid Body State Variables in Solid Immersed Simulation Hamidreza CFX 1 October 19, 2009 06:14
Extracting fluid flow region from a solid body 3D Pradeep Main CFD Forum 6 January 29, 2009 11:13
Rotating solid zone Rajesh FLUENT 0 May 17, 2008 05:44
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
