Fortran Code(corona effect)
Old   January 30, 2006, 08:31
Default Fortran Code(corona effect)
Trushar
Hi
I am working on project related to ESP(electrostatic precipitators). I want to solve corona effect in ESP by using CFX. For that I am developing code(I use fortran) for this corona effect. I want to know that how can I incorporate this code with CFX. If any one solved this type of problem then guide me. Or any suggestion please….
Trushar
Old   January 30, 2006, 10:15
Default Re: Fortran Code(corona effect)
opaque
Hi Trushar,
Would you mind describing your model in mathematical terms? It is easy to add simple new models to ANSYS CFX via the ADDITIONAL VARIABLE hook..
Do you want to solve the electrostatic potential? Like in
div (permivitivity * grad (ElecPot) ) = 0
with Dirichlet or Neumann boundary conditions?
For this, you do not even need User Fortran...
Opaque..
Old   January 30, 2006, 11:04
ravi
Hi Trushar, i am also working on ESP.but i have some difficulties in cfx.because in my case i have to give screen blockages which are surfaces in between domain.so first i have used another software like ideas in that screen blockages option is there.so do u know that how screen bloackge is given in cfx?If u know in another code like fluent then pls also tell me. Thnaks
Old   April 13, 2011, 12:24
ousegui
ousegui is on a distinguished road
Hi
I'm doing the same things currently.
Can you explain me how did you model the corronna effect in CFX
ousegui is offline   Reply With Quote
Fortran Compiler-CFX12.1 Araz CFX 13 March 27, 2017 05:37
user routine, user funcion, or fortran compile effect on the memroy? princeps11 CFX 1 May 13, 2009 18:37
Intrinsic Procedure 'ISNAN' in GNU FORTRAN 77 hawk Main CFD Forum 1 April 12, 2005 22:13
visual fortran Monica Main CFD Forum 1 August 28, 2004 20:45
Fortran77 or Fortran 90 Swapnil CFX 2 November 26, 2002 15:16
