ansys-cfx12 CEL function error
Hi all,
I'm working with an User Fortran routine interfacing with ansys cfx. my problem is look like cfx-tutorial chapter 19 under title of "air conditioning". as the test case for linking CEL I did all options in this tutorial but when I write Command ( ! system ("cfx5mkext TStat_Control.F") == 0 or die "cfx5mkext failed"; ) in command line, The following error appears. "ERROR CCL parser failed with message: Perl Syntax errors detected: cfx5mkext failed at(eval 86) line1. " In fact I couldn't run cfx tutorial at first step!!! could anyone help me about this error??? Thanks to all, and thanks to CFDonline!! |
For windows:
thanks for your answer. which programs should i install for comiling? I think the error is because of having no program for compiling!!! best regards |
windows: intel compiler plus some development kits from microsoft. Do not have exactly in mind which. Check help or manual.
linux: portland group or gnufortran |
which version
thanks Dear joey
which version of "intel fortran compiler" should I install for ansys V12?? should I install "microsoft sdk platform"?? the Error I face with is ((The compiler command "ifort" could not be found.Please ensure that the compiler is on your PATH and try again)). thanks alot |
Do not know. Check the manual for that.
